Old 05-28-2008, 03:06 AM   #1
SuperCheyenne72
SuperCheyenne72's Avatar
Understanding Backfire
Long story short,
I just recently replaced my stock AC Delco sparkplugs with some "slightly used" (longer story) Splitfire plugs. In order to prep and clean my Splitfire plugs a bit, I used some WD40 and some Carb and Throttle Cleaner. I then gapped the Spitfire plugs to match exactly what the ACDelcos were at.
I pop all 8 in, and try to fire it up... it takes a while but doesnt catch. After pumping a few times it finally catches, but VERY rough... only to POP loudly and die. This goes on a few more times but never gets better.
Finally I decide to just replace the old ACDelco plugs back in.. and sure enough, it fires right up, with no problems.
So what caused the backfiring? Could it have been the slight moist residue from the Carb cleaner fluid still in the "spark zone" of the Splifires? Or could this have happened if one or two plug cables were not "snapped" in all the way?
'72 Super Cheyenne LWB
  • 350 V8 w/ TH400
  • MSD Pro Billet HEI Dist. w/ Splitfire plugs
  • Edelbrock Performer Intake Manifold and dual exhuast glasspaks
  • Edelbrock Performer 750 cfm
SuperCheyenne72 is offline   Reply With Quote
Old 05-28-2008, 03:29 AM   #2
Steelawork'n
Just hang'n around
Steelawork'n's Avatar
Re: Understanding Backfire
I've heard the Splitfires are not all they're cracked up to be.
Driving a '68 Chevy C20 and a '93 Astro Van. Lots and lots of mileage that I deduct each year.
Steelawork'n is offline   Reply With Quote
Old 05-28-2008, 04:17 AM   #3
mvfd70
mvfd70's Avatar
I've heard the same thing about the splitfire plugs. I've had mechanics and parts store guys tell me that OE is better than they are
1978 Chevrolet Silverado 3/4 ton 400 small block.
2000 F-250 Powerstroke
2002 GMC Yukon Denali XL
mvfd70 is offline   Reply With Quote
Old 05-28-2008, 04:47 AM   #4
SuperCheyenne72
Well to be frank, I've run Splitfires for quite some years now and this is the first time this has ever happened to me. But this IS also the first time I've ever tried a gap of .050 as opposed to my normal .034 gap. I went to the bigger gap because a mechanic suggested I had to do so since I have such a hot running HEI distributor.
While on the subject of plugs, has anyone heard of these, or tried em?
http://www.pulstarplug.com/
  • 350 V8 w/ TH400
Old 05-28-2008, 04:50 AM   #5
ed2552
ed2552's Avatar
I've heard good stuff about the E3 plugs, but never tried them. May try them on my new car
'67 C20, Under the Knife!, LWB, Eaton HO-52, Rear Coil Springs
72' GMC C2500, 350, TH400(?), Dana 60
'67 K10 4-spd., 305, SM465, Dana 44, 12 Bolt, RUST!
'65 C60 292, 4 spd, 2 spd Rearend, 15' Grain Box, MINT!
09 Yukon Denali 82k Miles 6.2L/6A
ed2552 is offline   Reply With Quote
Old 05-28-2008, 04:59 AM   #6
jeffspower
Well, Whoop-dee-do!
jeffspower's Avatar
I haven't heard anything good about the Splitfires, or Bosch. I put AC Rapidfires in my truck back around '96. Still in there today & I've never pulled one. Granted, I've only put about 13K miles on them, but they have been trouble free.
'68 GMC shortbox 4x4 350/SM465/T221- bought it in '83 SOLD
'72 K20 500 Cad/TH400/NP205 SOLD
'92 Chevy 2500 6.5 mech TD 4L80E crusty daily driver
'72 Monte Carlo... sweet low mile toy
'11 Dodge Challenger IE 392 6spd... midlife car
jeffspower is offline   Reply With Quote
Old 05-28-2008, 04:59 AM   #7
Myself
Sounds to me like a couple of them are no good. Take an ohm meter to them and see what they read out.
Myself is offline   Reply With Quote
Old 05-28-2008, 05:08 AM   #8
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
the .050 gap may well have been the problem too.
I've run them, and on a small engine, there was a huge improvement in MPG, and a bit in performance measured by a G-tech thing.
