Old 05-28-2008, 04:41 AM   #1
hughnews1
removing screws on the driver door
the damn screws that hold the window reg.. Help ! how do get them out ... rust never sleeps ...
hughnews1 is offline   Reply With Quote
Old 05-28-2008, 05:13 AM   #2
hughnews1
Re: removing screws on the driver door
never mind .. that is the old door and for the new door I got the new windpw reg..I had to take the part that holdes the glass window .. the PO had a broken window. and never fixed it .. till I came along .. now how to get the broken glass out of the steel item .. ???????????
Old 05-29-2008, 12:15 AM   #3
71tahoe
71tahoe's Avatar
Safety goggles, hammer and reg screwdriver.
But seriously, use the safety goggles no matter what method.
71tahoe is offline   Reply With Quote
Old 05-29-2008, 02:02 AM   #4
68shortstep
Looks good at 20-ft .....
68shortstep's Avatar
I second the motion on the screwdriver & safety goggles.
It helps too, if you heat the glass track a little bit, to soften the old rubber/butyl adhesive tape that holds the glass in the channel. It fits tight, and age & sun heat causes it to stick together pretty good.
Don't have to make the channel glow red hot, tho !!!
Just a bit to warm it up will help soften the tape & make it turn loose. You have to put new glazing tape in anyhow.
68shortstep is offline   Reply With Quote
