Old 05-28-2008, 04:58 AM   #1
dedjr67
dedjr67's Avatar
Clutch pivot ball
Does anyone know where to get a pivot ball for the z-bar on my 65 2wd. I just put a 283 in it and removed the 230 the pivot ball from the 6 cyl is welded to the bracket and cant be removed to use it I looked in Summit but can only find the clutch fork ball. any help would be appreciated. Dennis
dedjr67 is offline   Reply With Quote
Old 05-28-2008, 05:25 AM   #2
joe231
joe231's Avatar
Re: Clutch pivot ball
Check out thisLINKY
it is for cars, so dunno if it will work
CHEVY ONLY
Old 05-28-2008, 08:17 PM   #3
rickf
rickf's Avatar
Off the shelf at you local parts dealer. I got one at Napa.
There are at least two different lengths. My 230L6 used the short one. I needed the long one to work with a 350V8. On the V8 it mounts directly to the block, not a bracket like the L6. Even though my 350 came out of an auto-tranny setup, it had the hole present, drilled and tapped and ready to go.
rickf is offline   Reply With Quote
Old 05-28-2008, 11:55 PM   #4
oldblu65
oldblu65's Avatar
I got mine from www.lmctruck.com ! They are one of many truck vendors , that you can get parts from .
oldblu65 is offline   Reply With Quote
Old 05-29-2008, 02:09 AM   #5
AllenKarber
I got mine from Obsolete Chevrolet in Georgia or something like that.
Are they still in business or are they obsolete?
I just my pivot ball and arm back on yesterday. One time I pulled my engine and I found that my pivot stud was broken! It was still shifting fine though.
AllenKarber is offline   Reply With Quote
Old 06-01-2008, 03:21 AM   #6
dedjr67
dedjr67's Avatar
Ordered one from LMC for 9.95 thanks for the info
