How Bad Are My Brakes?
My brake light has been off and on for a month now and it just went solid red this past week. I've been too lazy to bend over and visually inspect them until today. I notice my driver side pads are fine, but my passenger side has a nice fingernail deep groove in the rotor.
Does the rotor need to be replaced now or can it be machined out? Will the rotor be fine if I just replaced the pads, or could the groove act as a nifty little cooling function just like those rotors I see with the holes in them?
'72 Super Cheyenne LWB
its all about the +6 inches
Re: How Bad Are My Brakes?
if the light is on, you have more problems than what you can see, it indicates a pressure problem between front and back.
If you have to ask... that means that they are bad. You should get them fixed!
![]() ![]() 400sb-350 crank 400 destroker!!! 377 2.02 dart pro1 alum.heads msd, holley db hooker pro-comps-3in exh. 3 spd. saginaw-3.73posi Flat Bed...want Reg bed...trades? |
#4 | ||
![]() Quote:
![]() The rotors can be turned if there is enough material left to machine. DO NOT just put new pads on it, as Longhorn mentioned, you need to completly go throught the brake system.....period! Brakes are a big deal dude, it's not just you, but people seem to put them off more than say a leaking rad hose. When your light came on, you should of checked them that day or the next! Being lazy could of killed someone, seriously!
R.I.P. Scott Kalitta
most likely its the master cylinder, then the prop valve, longhorn man is right when there is a change in pressure the light comes on. mc's are only like 30 bucks at your local parts store
'55 3100 2nd series short-bed stepside '70 Corvette coupe stingray '71 Chevelle 2-dr coupe SS clone '71 C10 long-bed fleetside '83 long-haired brunette wife |
![]() Join Date: Sep 2005
brakes are over rated
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
Well I decided to take it to a brake shop this morning. I've owned the truck for 7 years and have only done pad changes on it. I figured it was time for a complete diagnostic.
Take it from me, when someone asks "how bad are my brakes?" and says "the brake light came on..." it could result in the following: - Rear drum shoes, eating into drums - Rear drums, both shot - Right rear drum cylinder, leaking - Front right rotor, needs replacement - Front right bearings, loose and shot - Front left bearings, missing washer (my fault when installed) - Front pads, 20% life left - Front calipers, freezing up - All 4 shocks, shot probably 10 yrs. old Grand Total $1,330.00 plus tax
#8 | |
At least you are getting it fixed before you ran into something or someone. |
#9 | |
Wow!! Longhorn wasn't kidding whenhe said, "you have more problems that you can see" .... That's cool your getting them fixed, but you will need to do one of two things when you drive it again with all the new brake parts, wear a helmet or seatbelt, because when you step on the brakes your gonna smack your mellon on the windshield.... ![]()
