Old 05-28-2008, 05:23 AM   #1
1968SWBBigBlock
Active Member
1968SWBBigBlock's Avatar
Steering wheel alignment with new gear box
I installed my new steering gear box today - now my steering wheel sits crooked.
Do I pull the steering wheel and reclock it or do I pull the Pitman arm and reclock it?
The Pitman arm was supposed to be clocked identical to my old one when it was rebuilt but who really knows - it looks like it was not
1968 SWB
454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts
781 heads Ported with 2.19/1.88 SSTvalves
Lunati 60204 cam, Micro Trol lifters,
Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition
Holley 770 Street Avenger carb,Headers armor coated
Built by Watson Ruppel Performance in Sarahsville Ohio.
Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall
12 Bolt Eaton Posi 4.10 Richmond Gears moser axles
18.5" x 31" Hoosier Pro Street Radials
ET Classic 5 Wheels - polished
Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone)
Custom Paint & Body Work
Special thanks to my wife, my son and my money tree
1968SWBBigBlock is offline   Reply With Quote
Old 05-28-2008, 06:01 AM   #2
HoupPhotography
Re: Steering wheel alignment with new gear box
If all you want to do is straighten the steering wheel, unblot it and see it you can straighten it. If that doesnt work, disconnect the steering shaft from the gear box and rotate it (with the wheel on) until it is straight and put the shaft back on the gear box.
Leave the pitman arm alone, if you move that back and forth until the wheel is straight your steering is going to be off, lock to lock.
What you can do, is get the wheel center, count the turns left, get it back to center and count the turns right and make sure they are the same. If the count is way off, then you will need to move the pitman arm.
R.I.P. Scott Kalitta
HoupPhotography is offline   Reply With Quote
