Old 05-07-2002, 06:11 PM   #1
kdf38
Post tranny kick downs
Does anyone know where i can get an electric kickdown for a turbo400 tranny? My Problem:
Installed a four barrel edelbrock carb and was unable to use the old 2 barrel carbs electric kickdown.What can I do to solve this.
Thanks,
Kdf38
kdf38 is offline   Reply With Quote
Old 05-07-2002, 06:12 PM   #2
72chevyLWB
Got 20's????
72chevyLWB's Avatar
Post
Turbo 400 never had a manual kickdown. Turbo 350 did. A 400 uses a switch that goes by the gas pedal to activate it.
72 Chevy C/10
87 Chevy Silverado 4X4
www.geocities.com/chevylwb/chevylwb.html
Aberdeen South Dakota
WANTED: Drop Spindles
F/S: rebuilt Turbo 400 & Aluminum wheels w/ tires
99 Silverado Ex-Cab 2wd, Bagged&WhippleCharged
02 Sierra Ex-Cab 4wd 2500 HD
The 72 went down the road.
72chevyLWB is offline   Reply With Quote
Old 05-07-2002, 06:40 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Post
Some of them had the switch on the carb.
'69 G.M.C. 350/350. Trying to clean up the left over damage from the Dope-Smokin-Old-Man
I've been dubbed the Longhorn Freak/Fanatic/Expert, I just hope I can live up to it.
FINALLY got the HORNIAC...a '70 one ton Longhorn with a Pontiac 350/350 and lots of 'personality'. Check out The Longhorn Webite.
If you need a pic posted, E-mail me at longhornmail@yahoo.com
My name is Andy...not Randy...I'm in Ohio...Not Illinois...close enough?
Columbus Ohio
Old 05-07-2002, 06:46 PM   #4
Project1970
14.1 @ 96MPH
Project1970's Avatar
Post
Yeah, my TH400 has it on the carb. It's not an original tranny, though.
Project 1970 - soon to be seen at http://milhouse.treylis.org:81/
Project1970 - LS1 Swap Complete!
Project1970 is offline   Reply With Quote
Old 05-07-2002, 09:56 PM   #5
69 longhorn
Post
The 400T will shift down from 3 to 2 without the elect kickdown. The elect only provides a 3 to 1 kickdown,& I dont use it on the longhorn(4.10 gears wind the snot out of the engine on a 3 to1 kickdown)......69longhorn.
http://community.webshots.com/user/hotrodhorn
69 longhorn is offline   Reply With Quote
Old 05-07-2002, 10:23 PM   #6
billogna
billogna's Avatar
Post
Here's my riggin' I made for my Edelbrock. I got a microswitch that's side to side actuated by a long spring wire. The wire rides in between the carb arm and the screw head. I used to use a penny w/ a hole drilled in it until I found the large flat headed screw.
I have found a couple switches w/ the bracket in the junkyard that were mounted on Quadrajets, but haven't tried to make one work yet. The switch is about 5" long.
I found an original wire harness, too, but it was really brittle, so I had to splice it anyway.
I saw an aftermarket setup, maybe made by Lokkar?, that was a TH350-looking cable setup that ran down to an electric switch next to the tranny, but I can't find the catalog right now.
'69 Chevy Custom/10 SB
'74 GMC Suburban 4x4
'66 Mustang Sprint
'77 Sportster
'69 Chev Cust/10 swb, 350/700R4, 5"/6"
'70 Chev C10 swb, 67 front, 454/700r4, 4"/5"
'73 Chev stepper, 350/3 spd
'84 Chev K20 350/4 spd
'91 GMC 1500 Suburban 4x4, 350/700R4
billogna is offline   Reply With Quote
Old 05-07-2002, 11:21 PM   #7
billogna
billogna's Avatar
Post
I found my Lokar Performance Products catalog. The kickdown kit was $62.95 in 1998. They probably have a web address by now, but I have thier phone #: (423)966-2269, in Knoxville.
Old 05-07-2002, 11:25 PM   #8
BIG ORANGE
BIG ORANGE's Avatar
Smile
Can the factory switch be purchused any where? I would like to have one for backup.
1971 chevy suburban (BIG ORANGE)
1970,68,90 swb Little BUCKS one day
67/72 truck parts bought/sold
LIFE IS GOOD,THANK GOD FOR IT!
Things happen for a reason!
BIG ORANGE is offline   Reply With Quote
Old 05-08-2002, 12:15 AM   #9
fleetimus
fleetimus's Avatar
Post
I used the Lokar. Bought it from Summit. It works great. I also have an Edelbrock.
68 Chevy l/b, 4 whl disc in the foothills of No Calif
fleetimus is offline   Reply With Quote
Old 05-08-2002, 01:34 AM   #10
jason7627
Post
just put a b&m kickdown switch on my buddy's 58. Part number is 20297. Kinda ugly but it works.
72 lwb 468/th400/3.73 2/4 drop primer
jason7627 is offline   Reply With Quote
Old 05-08-2002, 03:00 AM   #11
90\87Formula
90\87Formula's Avatar
Post
I believe the switch can be purchased at your local Chevy dealer. My 81 C20 had one mounted on the pedal from factory.
Abilene, TX
69 C10 Fleetside
307\Powerglide upgraded to '81 350\TH400 (want 700r4)
90 Firebird (87 Formula motor\trans)--daily driver
72 GMC-soon to be on 81 3/4 frame
82 Trans Am--soon to be big block
Robert
Member 1532
90\87Formula is offline   Reply With Quote
