Old 05-28-2008, 08:02 AM   #1
Pont406
Seat will not latch
I can't latch the seat on the right side. It's real bad when I have someone in the truck. Right side of the seat will move when braking. I took pics with the seat resting and pushing on it. Any ideas what might be wrong with it? I have a feeling that I will need a seat frame.
Pont406 is offline   Reply With Quote
Old 05-28-2008, 09:55 AM   #2
67chevyguy
67chevyguy's Avatar
Re: Seat will not latch
I had the same problem with mine. Looked underneath and found a hole than went through the seat rail and slider so I stuck a bolt through it. I didn't thread a nut onto it so if for some reason I need to slide the seat, I just pop the bolt out and slide away.
that hole may have been drilled by the p.o. to fix the problem the same way though. I'm not sure.
67chevyguy is offline   Reply With Quote
Old 05-28-2008, 11:32 AM   #3
red71cheyenne
Back in the sticks
red71cheyenne's Avatar
There's a piece that slides in and out of the track that locks it in place. Its attached to the rod that runs from the seat adjuster on the driver's side and has a sping on the outside(passenger side) with a keeper on it. May have just popped off. Mine did and it did the same thing til I put the spring and keeper back on.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection
1969 K5 Blazer w/Tuned Port
2010 2SS/RS Flaming Orange Camaro
2011 K1500 Suburban
2014 K1500 Pickup
2008 Nissan Altima? The wifes' hoopty
red71cheyenne is offline   Reply With Quote
Old 05-28-2008, 03:25 PM   #4
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Check out this link for some photos of how the brackets are set up. I just installed a bench in my truck, let me know if you have any questions.
It sounds like it's either stuck or broke. Easiest way to see what's wrong it to pull the seat, in my opinion.
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 05-29-2008, 05:22 AM   #5
Pont406
I removed the seat and found rod, springs and other parts. I also found more rust. I didn't have time to look at the seat yet. I will try and fix it this week.
Old 05-29-2008, 05:09 PM   #6
LockDoc
The Older Generation
LockDoc's Avatar
It looks like you have all of the parts to put it back together.
lockDoc
Leon
Old 05-29-2008, 09:45 PM   #7
72BlckButy
Tot Roddin'
72BlckButy's Avatar
the little bar laying on the floor is causing the problem with the seat not latching. It's not the best shot, but take a look at the pics below... hope this helps. If you need better pics, I have a spare bracket that I can use to get better pics with.
-Nate
Old 05-31-2008, 04:25 AM   #8
Pont406
I was about to mig the seat tracks. But I after I saw the pics I got it all back together. Some pics of it back together. Factory sound insulation looks ok. Do you guys put insulation back or not? Thanks
Old 06-02-2008, 03:14 PM   #9
72BlckButy
Tot Roddin'
72BlckButy's Avatar
I didn't and everything appears to work out okay.
Glad to hear that you were able to put the brackets back together! I hope they work now.
-Nate
