Junior Member
402 engine compression???
Does anyone know what the engine compression test results should show for a 396/402 motor??? I need the proper range it needs to be in?? PLEASE
going to sell this one...looking for a SWB project next. |
Re: 402 engine compression???
what year is the engine? There is alot of difference between a 68 and a 72.
72 Cheyenne Super 80 Silverado Blazer 2wd |
Junior Member
1970 402 big block. I needs compression specs taken from the spark plug hole....not ratio compression..thanks
Lowest cylinder should be within 15% of the highist. Spark plug compression depends on what kind of cam you have and the wear on the engine.
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
