Here is the 1000th question.. Sorry!
Well not really but it sure does seem like it..
My fuel gauge in my truck always reads full... I was about to buy a new sending unit but was thinking if it went bad it would be an empty reading? I don't mind spending the money to get one but just would like some idea on what to look for.. Gauge? Sending unit or? This is the stock location tank, with stock dash and gauge...
1949 Chevy 408 CID stroker 6.0l with a few add ons, 4l80E, 4 Wheel Disk Brakes and a set of GT35 going on soon. |
Re: Here is the 1000th question.. Sorry!
58 Apache short fleetside ona 64 chassis: ![]() |
I read that and I am a bit confused... My gauge goes straight to the full mark when the key is on.. I am assuming that I have a bad ground.... Am I correct saying this?
#4 | |
Having just read that article and my experience with sending units, I would say that you should pursue this first. I can't remember the last time I replaced a gauge. Poor or missing grounds will create all kinds of strange problems. That test you did with key on and full gauge is exactly like in descrition. Check out those wires and terminals and let us know. Dave
R.I.P ESLL Even as the body dies the spirit lives on in the people you touched |
I am assuming that your tank is still behind your seat and you can get easy access to it by flipping the seat forward and pulling the cover back to expose the wiring and sender unit. You can disconnect and reconnect the wires while watching the guage with the key on. Process of elimination. But yes, my guess is it's a grounding issue. Just can't remember what it takes to peg the guage to full. Good luck and let us know the outcome.
Will do and thanks for your help... And yes everything is still in the factory location on my truck...
I went out and looked at my sending unit in my tank. There is one stud for a wire and one screwed into the tank..
As mine is hooked up now it has the ground coming from the direct screw in and the power to the stud.. Is this backwards?
Mine looks like this:
![]() If you disconnect the power lead it should go to empty. Cadman
56 GMC 1922 Dodge Rat Roadster 89 Gray Allante 90 Red Allante Turkey Run Photographer http://www.turkeyrun.com/photo_gallery.html Last edited by cadman89; 05-30-2008 at 10:31 PM. |
Mine goes ot fulla s soon as the key is on... Take th epower wire off and it is still at full..
Her eis mine.. Not nearly as clean as yours.. The yellow wire is just an added ground that I did testing it.. ![]()
Could be the sending unit is toast. It looks older than God. You can remove it for further testing, but be careful. Don't want to make the rest of the truck toast.
I went ahead and ordered a new sending unit from Classic Parts.. I will have it in here on Monday
Thanks fo rthe help...
Was the sending unit.. Had about 2" of the positive wire gone from inside the tank...
#13 |
Ain't it great to have those kind of issues done and over with?!? Glad to hear the mystery is solved.......but there is always something else.
#14 |
Isn't that the truth.. Going to charge the a/c this weekend... I wonder what i will find next...LOL
