Old 05-28-2008, 08:30 PM   #1
Zonaman
Zonaman's Avatar
Question Little help with a fuel line please.
I've got a '69 half ton that needs a new fuel tank sending unit. I want to install the unit for a '72 because I've heard the vent line can be used as a return line if I decide to fuel inject the engine. Problem: The line immidiatelly following the unit connects with a flair nut and the '72 looks to be couple with hose & clamps. I don't seem to be able to find just that segment of the fuel line from the sender to under the cab floor that fastens with hose and clamps. Can that be ordered anywhere or do I just get some tubing off the shelf and bend it?
Thanks.
69 C-10 LWB, 350, 700r4, 3.73 posi-traction, front disc brakes. Built for the desert- She can take the heat! Vivat Rex Chevus!
Zonaman is offline   Reply With Quote
Old 05-29-2008, 12:10 AM   #2
70c10
67-72 Addict!
70c10's Avatar
Re: Little help with a fuel line please.
You can just buy the tubing and bend it from the sender thru the floor. Like this:
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
