Old 05-28-2008, 09:29 PM   #1
Hair
Bench wont fold up
I've been trying to fold the bench seat foward in my truck, but it won't budge, and I can't find and levers or knobs or nothing to pull on to make it fold foward so I can have access to get behind the seat. Now I'm thinking it does NOT fold foward at. Is that right? Do some bench seats not fold foward or is there some kind of trick to this? I'm fixin to just unbolt the whole seat and take it all out unless I'm missing something here. What makes me think it folds forward is that the previous owner has stuff back in there behind it, but then again...maybe that's why he left it back there lol. 71 GMC
Hair is offline   Reply With Quote
Old 05-28-2008, 09:34 PM   #2
kyull67
kyull67's Avatar
Re: Bench wont fold up
My seat has wingnuts you have to unscrew before folding it forward, but that's in a '67. I don't know if it's the same as yours.
kyull67 is offline   Reply With Quote
Old 05-28-2008, 09:36 PM   #3
forsale
Mine don't fold
forsale is offline   Reply With Quote
Old 05-28-2008, 09:48 PM   #4
ksjh1316
ksjh1316's Avatar
My 71 GMC doesn't fold
My 67 Chevy does
Don't know if there was a cut off year I remember something about the folding seats not being safe in crashes
ksjh1316 is offline   Reply With Quote
Old 05-28-2008, 10:02 PM   #5
68gmsee
Active Member
68gmsee's Avatar
As far as I have seen, the majority don't fold. I have heard that some trucks came with a lever to unlatch but I haven't found them.
What some have done is remove one of the two bolts so that it will fold forward. Or you can put wing nuts like kyull67's.
Be aware that if they are the original bolts, they can be a bear to remove. At least mine were. Now that I've got a seat that folds, I really don't have any reason to do it..
68gmsee is offline   Reply With Quote
Old 05-28-2008, 11:59 PM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
most don't... in 67 and 68, it seems the stripped down trucks would fold.
Removing those bolts, or adding wing nuts, will probably mess up the vinal on the side of the seat.
Old 05-29-2008, 12:04 AM   #7
70c10
67-72 Addict!
70c10's Avatar
Here's a pic of my folding bench. Look at the triangle shaped piece above the seat belt. You lift that up to fold the seat forward.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 05-29-2008, 12:05 AM   #8
Longhorn Man
Jim... I've never seen a seat that looked anything like that stock in a 67 - 72. Any idea what it came out of?
Old 05-29-2008, 12:27 AM   #9
70c10
67-72 Addict!
70c10's Avatar
I always assumed it was from a 67/68. It was in the truck when I bought it. Maybe not?
Jim
Old 05-29-2008, 02:08 AM   #10
Bob D
Rolled on Paint Club
Bob D's Avatar
That is a seat out of a Ford Pickup. I read somewhere that they fit and offer a few extra inches of legroom over the stock bench seat. Here is a pic of the seat in my wrecked 1990 F150:
Bob
1970 GMC 1500 swb fleetside
SB 355ci.
Smog heads
Summit 1102 cam
Performer intake and carb.
Finally in about 1 piece in the yard.
Bob D is offline   Reply With Quote
Old 05-29-2008, 03:25 AM   #11
70c10
67-72 Addict!
70c10's Avatar
Bob
Wow! I never would have thought that! The next time I go to the junkyard I'll have to check the 1990 models. Somebody must have used our truck floor mounts and attached them to the bench unless they are the same. This is good info to know for somebody looking for a seat! Well after checking around on the net it appears to be from the 87-91' model years of F%$D trucks.
Jim
Old 05-29-2008, 10:32 PM   #12
Hair
A ford seat??...a ford seat??...Come on guys...a ford seat has more leg room because people who drive fords have bigger legs from doing all that walking and pushing.
Old 05-29-2008, 10:56 PM   #13
cruiserman
My 68 folded. 72 does not.
72 C2500 LWB 402 Sierra Grande
05 Odyssey
08 Tundra
cruiserman is offline   Reply With Quote
Old 05-29-2008, 11:23 PM   #14
thewrai6th
I was told by the owner of VintageChevyTrucks.com that they stopped making the folding seat in 1969. The reason was the seat folding forward during hard braking and head on crashes.
1969 Stepside restoration
thewrai6th is offline   Reply With Quote
Old 05-30-2008, 12:11 AM   #15
Longhorn Man
I know in cars, starting in 68 the seat backs had to latch.
Old 05-30-2008, 01:08 AM   #16
jorgensensc
jorgensensc's Avatar
In my '72 I took the top bolt out of the side bracket and used one of those Pins with the key ring thing on it in place of the bolt. It keeps it stationary, until I pull the pin and folded the seat forward. Worked for me.
Shawn
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
