05-28-2008, 11:18 PM | #1 |
HELP!! Brakes went out!!
The pedal is just going to the floor now. I've always had pump it some, and some times at a redlight, the pedal would go to the floor after a minute or so, and I would have to repress the brake pedal and all was well. Yeterday though, on the way home I had nothing. I was near the neighborhood so I was able to get it home and into the backyard. I pulled the front wheels and loosened the line at the caliper. I had my daughter push the brake pedal and fluid was coming out just like it should. So, do you think its my calipers? What are the chances of both front calipers going out at the same time though?? Could it be the booster? Please help, and thanks for any thoughts
71 C-10 98 Mustang GT 06 Mustang GT Last edited by stanglifemike; 05-28-2008 at 11:19 PM. |
05-28-2008, 11:39 PM | #2 |
Re: HELP!! Brakes went out!!
sounds like the master cyl. to me. those are all the symptoms
1967custom |
05-28-2008, 11:43 PM | #3 |
So brake fluid would be going to the calipers even though the master cylinder went out?
71 C-10 98 Mustang GT 06 Mustang GT |
05-28-2008, 11:50 PM | #4 |
If your brake fluid is at normal capacity, I would suspect the master-cylinder.
05-28-2008, 11:51 PM | #5 |
Brake fluid under no pressure would still flow from the master cylinder. Once resistance is met in a pressurized system, the fluid pressure will just balance in the MC. (no pedal)
05-28-2008, 11:51 PM | #6 | |
its all about the +6 inches
You need to step back and look over the whole system.
Park it on dry pavement if you can. Check the master clylinder... is it full... on both halfs? When you top it off (I'm gonna assume 1/2 of it is bone dry) and pump the pedal, do you hear fluid splattering? Are you seeing any puddles forming? look on the back side of your tires... are any of them wet? There's a LOT more to it than calipers up front and a master cylinder, and any guesses with what little info you gave us... is nothing more than a guess. Your initial problem; Quote:
05-28-2008, 11:51 PM | #7 |
I am a Referee of life.
"Usually" when a MC goes 'out' it is bypassing fluid around the piston in the MC.If that is what's happening then the fluid will flow out the line or bleeder.This is because the fluid will flow thru the path of least resistance.If you want a sure check you will need to hook a pressure guage to the system.
If you had no brakes then your rears are also not working.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
05-28-2008, 11:52 PM | #8 |
OK cool, thanks for the quick responses guys!! Is it simple to swap out, or anything tricky I should look for. Any special tools, etc..
05-28-2008, 11:53 PM | #9 |
Simple but be sure to bench bleed it to get the air our before you install it.
05-28-2008, 11:54 PM | #10 |
How do you bench bleed ??
05-28-2008, 11:56 PM | #11 |
By the way, I put new pads and rotors on the front about 10 months/1500 miles ago
05-29-2008, 12:00 AM | #12 | |
05-29-2008, 12:01 AM | #13 |
Long shot, but one time I had a simular problem and I changed the MC and it did not help any. It turned out to be just the vac. gromet the goes into the booster.
72 Cheyenne Super 80 Silverado Blazer 2wd |
05-29-2008, 12:09 AM | #14 |
a vac grommet on a booster shouldn't cause the pedal to go to the floor, it should cause a rock hard pedal that is hard to move down at all.
The rear portion of the master cylinder was empty, and there is no evendence of fluid anywhere? You probably are looking at a bad master cylinder. but there's bad news here too. If you have power brakes, then all that fluid went in the booster, where it is now eating the rubber lining of the diaphram. It will end up popping the booster. You can run it, but I would recomend getting it replaced. I personally lost an engine due to the instant lean condition when my booster popped. |
05-29-2008, 12:22 AM | #15 |
thanks for the heads up!!
