Project 7dos
Good Carbs?
Hey guys,
We had a nice little Speed Demon carb on for a while, but we could never tune it right, so we put a rochester on it, runs great. I'd like to try another carb though, so what kind are ya'll running? It's a 350 bored .30, vortec heads, headers, big cam, etc.
7DOS - 1972 C-10 350/350 Porterbuilt/Accuair 20x8.5/20x10 Ride Low or Die PSSST - Yes it's bagged. 7dos build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=610290 |
Edlebrock 600 cfm with electric choke on my 68 with a 350.
Holley 600 cfm on my Z28 with manual choke with a 350. Kind of hard to warm up in the winter. Holley 600 cfm with electric choke on my 71 Mach1 with a 351 cleveland. All of these perform pretty much the same. Kerry
1969 Chevelle 1990 IROC Z Convertible 2002 Silverado LT |
Re: Good Carbs?
Edlebrock 600 cfm with electric choke on my 72 with a 350/350. it aws a plug N play .
Trueman |
![]() Join Date: Oct 2005
Re: Good Carbs?
I concur.....if you don't have the patience to dial in a carb, Edelbrock makes the most sense and typically works good right out of the box.
72 Cheyenne SWB Fleet Nut & bolt frame off in progress...99.9999% - supercharged 383 - 4 wheel discs - relocated fuel tank - ![]() My Build Thread |
Re: Good Carbs?
Holley Street Avenger. Took some tuning, but works great. Don't even need the choke in the warm months. It even fired right up and ran great after setting on the shelf all winter (during a build project on the truck).
Plug and play, they're not (most of the time). If that's what ya want, get an Edle, or Q-jet. But my Holley runs like a champ, and has since it's first tune (2.5yrs). Jay
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape. If a hammer doesn't fix it, you have an electrical problem! Slot Cars, 1:24 Scale, 100MPH@100,000RPM, fastest things on wheels! ![]() |
