buffle
4oo turbo driveshaft
Need to know if one piece drivshaft form behind a granny 4 speed will work on my shortbed w/400 turbo. Seller says it has a slip yoke, already have 400 turbo rear yoke.
Re: 4oo turbo driveshaft
Turbo 400's are a little longer than your 4 speed transmission so it depends on whether or not the slip joint will collapse far enough and if the u-joint on the drive shaft will fit the 400 yoke.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
i had a granny trans in my 68 and i swapped it out for a short shaft turbo 400 and the difference was almost 9 inches....i am getting a shorter shaft made for the 400 so my 2 cents would say no....
