Old 05-29-2008, 03:46 AM   #1
rizick
rizick's Avatar
6 cylinder mpg
what kind of mpg could a person expect from a 6 cylinder 1 barrel with a 3sp (manual) on a 66 chevy 1/2 ton?
rizick is offline   Reply With Quote
Old 05-29-2008, 04:23 AM   #2
PA66C20
PA66C20's Avatar
Re: 6 cylinder mpg
I can't answer that question yet because I'm still trying to get my 66 1/2 ton running. But I know there is a big difference in mileage between the L6 292 and the L6 250 I don't know which one you have.
How can you tell if its a boy or a girl?
Guess we'll have to roll it over to find out!
PA66C20 is offline   Reply With Quote
Old 05-29-2008, 05:45 AM   #3
SkylineNXS
SkylineNXS's Avatar
Re: 6 cylinder mpg
I have a 66 250 1 barrel and im pretty sure i got like 20 on the way from champaign, IL to monroe, WI. Its like 5 hrs....
2000 GMC Sierra EXT Cab Short 4x4, finally mine...
1966 C10 SWB Fleet, 250 I6, three on the tree....
Previously Owned....
1987 Chevy R10 "Silverado" (at least the badges were) Short Step 350 700r4....
1972 Chevy LWB Fleet 350/350
EXTENDED CAB ALL THE WAY!
.._..~...-...._...____
.._..-...______|_|__\____
..-..~.|_(O)__|_|__|_(O)]
SkylineNXS is offline   Reply With Quote
Old 05-29-2008, 06:30 AM   #4
greg64
greg64's Avatar
Re: 6 cylinder mpg
My 77 C10 with a 250 and 4 speed gets around 16 mpUSg. When it was under full load pulling a heavy trailer, I managed 9 mpg traveling at 55 mph. The weights and aerodynamics are probably about the same.
Overdrive would probably help a lot and that's what I'm doing on my burb.
Greg
64 GMC Suburban - 283, NV3500, 14 bolt
77 C10 swb - 292, SM465, 12 bolt
greg64 is offline   Reply With Quote
Old 05-29-2008, 03:39 PM   #5
rizick
rizick's Avatar
Re: 6 cylinder mpg
I am not sure if it is a 250 or a 292. How would I know? I am reasonably sure the motor has been taken out at least once, I haven't had this truck that long, but I am thinking about concentrating on making it my daily driver and retiring that gas guzzling 2500 hd. Thanks
Old 05-29-2008, 04:18 PM   #6
Tim64
Tim64's Avatar
Re: 6 cylinder mpg
The best thing you can do for mpg is going with a tranny that has overdrive.
Tim64 is offline   Reply With Quote
Old 05-29-2008, 06:08 PM   #7
greg64
greg64's Avatar
Re: 6 cylinder mpg
There's a couple of ways to tell the 230/250 from the 292. On the 250, the engine mounts are directly across from each other. On the 292, the passenger side mount is 4" further forward (fuel pump behind the mount).
The second way is the pushrod covers. On the 292 they're about 6" high, but on the 230/250 they're 4" high.
Grab the casting number off the block and look it up on inliners.org if you want to be sure (or if you have a 230/250).
Greg
Old 05-29-2008, 06:38 PM   #8
rizick
rizick's Avatar
Re: 6 cylinder mpg
thanks my truck apparently is the 250. the motor mounts are across from each other and the valve covers are only 4" high.
Thanks for the reply about overdrive transmission but putting in an overdrive transmission is more than I would be prepared to tackle, fuel economy is not a major consideration but I do give it some consideration now that I am leaning toward making this my daily driver, I will be looking for ways to improve fuel economy, a friend says 15" tires are more fuel efficient then 16" and snow tires are fuel hogs. I would not have thought of that one.
Old 05-29-2008, 09:53 PM   #9
PA66C20
PA66C20's Avatar
Re: 6 cylinder mpg
I was doing some research in my book and found out that the best tires for a 2wd c10 for our year is a 15" if its a 4wd you're supposed to go with 17". If you are going with a larger tire and want good gas mileage for it, you will have to change the gear ratio accordingly.
