Old 05-29-2008, 04:18 AM   #1
87Lowrider
Navy Radioman Veteran
87Lowrider's Avatar
I read a thread recently here where someone was recommending *****************'s brackets and bags for the front of 73-87's.
Over this past weekend, I pulled out the springs that had 1 1/2 coils removed from them and replaced them with the stock ones that I received when I bought the truck from the previous owner last summer.
The nice thing was that the cut springs dropped the front to a level I really liked except when I turned a corner. With the well tops cut out by the previous owner, it did pretty good but once I put the 454 in, I also put in new wells so I had to raise it up a couple inches so it won't rub under normal conditions, so bags seem like the best option.
Problem is, the stock springs raised it nearly 5 inches in the front which puts it higher in the front than the rear. What to do???
thanks for your input... Kenny
87Lowrider is offline   Reply With Quote
Old 05-29-2008, 04:42 AM   #2
larry may
Re: *****************
might ask about the raised front end in the suspension forum, go with drop spindles to fix the problem?
The biggest problem people have, is other people
Thou shalt be cool and not hassle
Be a site supporter.
The heart of the wise inclines to the right, but the heart of the fool inclines to the left." Ecclesiastes 10:2
larry may is offline   Reply With Quote
Old 05-29-2008, 04:46 AM   #3
87Lowrider
87Lowrider's Avatar
It already has 2 1/2 drop spindles in it.
Old 05-29-2008, 05:08 AM   #4
lolife99
67-72 parts collector,…
lolife99's Avatar
Cut your stock springs for now. Rule of thumb: 1/2 coil = 1" of drop.
Keith
Convert to disc brakes.
Old 05-29-2008, 09:28 PM   #5
killthewabbit
Spear and magic helmet!
killthewabbit's Avatar
I've always heard suicidedoors' brackets for bags were great, too.
http://www.*****************/67-87Ful...rtBrackets.php
Hard to beat the price, if you're getting ready to bag the front.
-- Will
killthewabbit is offline   Reply With Quote
Old 05-29-2008, 09:34 PM   #6
tvblazer78
Low & Fast!
tvblazer78's Avatar
I have them, they are good....
tvblazer78 is offline   Reply With Quote
Old 05-29-2008, 09:53 PM   #7
dieselarmy13
Phone's ringin Dude.
dieselarmy13's Avatar
I would fully recomend SD.com for anything. They know their stuff. I prefer to call in an order vs. over the web, but that is personal preference. They're usually real cool over the phone and will be happy answer any questions. ALTHOUGH, I wil say, every now and then I get this one b-hole on the phone that isn't so cool. They are about the cheapest you're going to find.
I pitty the fool with only two headlights!!
2003 SILVERADO SS--THE NEW GIRL
1972 GMC--THE OLD GIRL
dieselarmy13 is offline   Reply With Quote
Old 05-29-2008, 10:02 PM   #8
Bad Karma
Magnificent bastard
Bad Karma's Avatar
I've always wondered, do you have to cut a little off the ends of the swaybar with bags or not?
1977 Big Block Burb
Bad Karma is offline   Reply With Quote
Old 05-29-2008, 10:15 PM   #9
tvblazer78
Low & Fast!
tvblazer78's Avatar
No, it work ok with out doing that..
Old 05-29-2008, 10:28 PM   #10
Bad Karma
Magnificent bastard
Bad Karma's Avatar
Cool deal, I may have to get myself some air suspension up front. I'm tired of replacing lower control arms...
1977 Big Block Burb
Old 05-30-2008, 12:12 AM   #11
Locomark
I've got those items as well. I am still getting all the pieces together for my air ride but they look good.
Loco
Locomark is offline   Reply With Quote
Old 05-30-2008, 02:25 AM   #12
75silverstep
KEEP ON TRUCKIN.
75silverstep's Avatar
got my brackets last week and bags should be here friday..they were on back order from suicidedoors also..call in to order for sure ,on the site it didnt say the bags were on backorder..Hey tvblazer did you cut your bottom cups at all.I heard taking a 1/2 in off wont hurt ..I need this thing as low as i can go ...and thanks for the sway bar answer i was woundering the same thing ...
1975 C-10 STEPSIDE (ALMOST DONE AGAIN)90 percent done wheres that other 10 haha .1994 GMC Z71 .
75silverstep is offline   Reply With Quote
Old 05-30-2008, 03:49 AM   #13
87Lowrider
87Lowrider's Avatar
Alrightythen,
I'm convinced....how 'bout a parts list to get this system going? '87 SWB, 454, 700R4.
Thanks Gang!
Kenny
Old 05-30-2008, 03:33 PM   #14
tvblazer78
Low & Fast!
tvblazer78's Avatar
I think I took off about a 1". I would have to look at it again. Are you going to run stock inner finder wells? If so a 1/2" would be safe.
Old 05-30-2008, 03:39 PM   #15
tvblazer78
Low & Fast!
tvblazer78's Avatar
Here is what I got,
Old 05-30-2008, 03:41 PM   #16
tvblazer78
Low & Fast!
tvblazer78's Avatar
And more, now if you click on each pic to save, it will tell you what each one is... Hope this helps..
Old 05-30-2008, 09:12 PM   #17
75silverstep
KEEP ON TRUCKIN.
Thanks ...Yes i have stock fender wells but will only be laying out when stopped and im on 18s not 20s if that will make a diff. i think i will cut them 1" what the hell haha...I can always cut the other half if i will work ..Still love your ride ..Gota do a new photoshop for you with the new wheels .
Old 05-30-2008, 10:51 PM   #18
jimmydean
jimmydean's Avatar
I would also recommend the SD cups. I ran them last time and would run them again for sure.
As for cutting, don't just hack off some amount. Set the cup in the arm and see where it sits. You don't want it to sit below the arm itself. If the cup sticks up 1", then that's how much to cut.
Some people have cut too much off and had the bag hit the arm (not good). Better to see the fit before cutting.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 05-31-2008, 04:29 AM   #19
87Lowrider
87Lowrider's Avatar
Thanks for the list... I'll save them and call SD. BTW.. I'm sure you haven't herd it b4 but sick blazer... I'm a blazer guy too... We're gonna try to get to pigeon forge this fall for shades of the past.
I still have suspension to finsh, bucket seats to find and install, console and sealed flat black to put on this summer.
Kenny
Old 05-31-2008, 02:01 PM   #20
tds
are any of you guys having any problems laying out on stock arms? was thinking about this plate and cup combo. also what bags are you guys using?
1981 - C-10 SCSB
Planning on putting this thing on it's rocker!
tds is offline   Reply With Quote
Old 06-01-2008, 12:03 AM   #21
tvblazer78
Low & Fast!
tvblazer78's Avatar
Air bags are firestone 2600..
Kenny,
Thanks and I may seya later this summer, PM me before you come down and we can met up or something.
Thanks,
Trav
Old 06-01-2008, 04:27 AM   #22
87Lowrider
87Lowrider's Avatar
Kenny,
Thanks,
Trav
Thanks! - Will do.
Old 06-02-2008, 03:16 AM   #23
tds
how do you like the firestones?
1981 - C-10 SCSB
Old 06-03-2008, 10:52 PM   #24
87Lowrider
87Lowrider's Avatar
I called SD.com today, talked to Ricky and they have everything in stock except the 2600's. They'll be in on Thursday. Nice thing... their on 50 miles from here.
I'm going up on Friday to pick up parts... so bags all around this weekend!!! WooHooo!
I'll post b4 and after when I'm done.
Kenny
Old 06-03-2008, 11:50 PM   #25
tvblazer78
Low & Fast!
tvblazer78's Avatar
Kenny
Sweet!!
