05-29-2008, 03:12 PM | #1 |
go cyclones
Need some help
Well not labeling everything is starting to come and bite me in the A$$. Could you expects tell me what each item is and where it is located.
Thanks |
05-29-2008, 03:28 PM | #2 |
Re: Need some help
Appear to be horn relays. Why you have three? they would be installed on the drivers side in cab on the firewall up high.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
05-29-2008, 03:29 PM | #3 |
Re: Need some help
They sometimes go bad so don't pitch the extras.
05-29-2008, 03:35 PM | #4 |
Re: Need some help
Now I notice some have different plug connectors. I believe there is a relay for the A/C & heater somewhere also to inside the cab.
05-29-2008, 04:13 PM | #5 |
The Older Generation
Re: Need some help
The one on the left is the horn relay. LockDoc
05-29-2008, 05:03 PM | #6 |
Re: Need some help
Yes, it's on the passenger side, up underneath the dash. The one on the right, I believe, is the high speed a/c relay.
Mike 2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip 1972 Chevy Suburban - Turquoise/Black 1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD Using your turn signal is not "giving information to the enemy" 67-72 FAQ |
05-29-2008, 05:07 PM | #7 |
Re: Need some help
The good thing about it is they all have different plug connectors so it shouldn't be hard to determine where they go. I replaced the under dash harness in mine and no two connectors were the same.
-Scott- |
