Old 05-29-2008, 08:11 PM   #1
FormerMember
Disk Conversion
http://cgi.ebay.com/ebaymotors/1963-...mZ200093722492
Anyone used these?
I am tempted. I know I could go down to the boneyard and pull a C10's front suspension out and swap it. I am just not up for that sort of project on this particular truck right now.
FormerMember is offline   Reply With Quote
Old 05-29-2008, 08:43 PM   #2
myoldchevytruck
Retired Air Force Veteran
myoldchevytruck's Avatar
Re: Disk Conversion
What year truck do you have? If you have drums, I don't think this kit will work. This is quoted from the eBay description: "These kits mount to your original spindle making installation a snap and use late model "GM" calipers for added clearance when running 14" wheels".
Correct me if I am wrong but spindles were not offered until 71'-72' and those were disk brakes. There's a number in the eBay add. I would call them and find out more about your particular setup. Good Luck.
Harry
69' SWB Step Side 1/2 Ton w/68' Front Clip
Swap from Leafs to Trailing Arms (Complete)
Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front)
3/6 Drop
Help Support The Board
Click Here For Information On How To Subscribe
Krue's FAQ Page
Vendors
myoldchevytruck is offline   Reply With Quote
Old 05-29-2008, 09:17 PM   #3
FormerMember
Re: Disk Conversion
This is to convert drum front brakes to disk, using original drum brake spindles...
Old 05-29-2008, 09:38 PM   #4
dieselarmy13
Phone's ringin Dude.
dieselarmy13's Avatar
Re: Disk Conversion
If you ask me, just save up a few more hundred bucks, and get a whole disk conversion kit from ECE or CPP. I got mine from CPP, and everything went great, but knowing what I know now, I would have gone through ECE.
I pitty the fool with only two headlights!!
2003 SILVERADO SS--THE NEW GIRL
1972 GMC--THE OLD GIRL
dieselarmy13 is offline   Reply With Quote
Old 05-29-2008, 09:46 PM   #5
FormerMember
Re: Disk Conversion
Why is that? I am in the market.
Old 05-29-2008, 09:58 PM   #6
myoldchevytruck
Re: Disk Conversion
We were lucky. Paid $150.00 for a rear 5 lug drum axle and 5 lug disk spindles and rotors. Change over from 6 lug was not that bad. Now were changing brake parts, so far everything is going smooth. I have heard that the kit from ECE is very good as is all of there other parts.
Harry
3/6 Drop
Krue's FAQ Page
Vendors
Old 05-29-2008, 10:04 PM   #7
dieselarmy13
Re: Disk Conversion
Because you get new spindles, ball joint, dust covers,ect, ect. You get it all, and it's actual truck stuff. No salvage yard scrounging. Just call Early Classic Enterprises and tell them you need a front disc conversion kit. They will hook you up.Their number is 559-291-1611. Probably the nicest guy I ever delt with. Fast shipping to boot. I get all of my parts through them now.
Old 05-29-2008, 10:06 PM   #8
Bus Ted Knuckle
Son of a gun
Bus Ted Knuckle's Avatar
Re: Disk Conversion
For that price you can go to a junk yard and get a whole crossmember, and it is really not that hard to make the swap. You would have to run two different bolt patterns front and rear, and that means two spares (not to mention a goofy look)
I dunno about it.
BEATERS ARE NEATER
Bus Ted Knuckle is offline   Reply With Quote
Old 05-29-2008, 10:09 PM   #9
FormerMember
Re: Disk Conversion
Actually, I meant the difference between ECE and CPP? I've dealt with both of them.
I dunno about it.
I have a Caprice 9C1 rear end ready to go, with disks and ebrake.
Old 05-29-2008, 10:19 PM   #10
dieselarmy13
Re: Disk Conversion
Oh, sorry about that. For one, ECE make's their spindles right here in the good ol' U.S. of A. I don't know where CPP's are made, but ECE put's their name right on the side of them, and to me, that say's alot. The only issue I had with CPP's kit is that I had to redrill my dustsheilds, and the stainless brake line kit I got from them didn't fit. Another board member helped me out with that, but I guarantee you, ECE would have told you that up front, so yo didn't have to run around looking for odd -AN fittings. Other than that, no complaints.
Old 05-29-2008, 10:22 PM   #11
mekdad
mekdad's Avatar
Re: Disk Conversion
I got my kit from GMC Paul's I got stock height spindles and the 6 lug kit all said and done 2 hour install and $475.00 good to go, fit good no complaints from me.
you never know what you can do until you have to undo something you have done!
mekdad is offline   Reply With Quote
Old 05-30-2008, 03:47 AM   #12
Ole Blue 68
Ole Blue 68's Avatar
Re: Disk Conversion
I've seen some kits like this before. In fact, I think CPP may sell one. Pay attention to the parts you'd have to use besides these brackets; Malibu and Chevelle parts. I'd be a little concerned about using car brake components up front on our trucks.
Go with ECE or find yourself a 73-87 front end.
Ole Blue 68 is offline   Reply With Quote
Old 05-30-2008, 06:33 AM   #13
extd56
extd56's Avatar
Re: Disk Conversion
The Chevelle uses a 5x4.75 pattern and the truck uses a 5x5 pattern so you will still need 2 spares and could not rotate them too easy. I believe the Caprice also uses the 5x5 pattern like the trucks.
extd56 is offline   Reply With Quote
Old 05-30-2008, 06:48 AM   #14
PipsC10
PipsC10's Avatar
Re: Disk Conversion
Another vote for ECE, you will not be dissapointed.
1970 2wd short/fleet 350/350 Project "iced green dream" http://67-72chevytrucks.com/vboard/s...d.php?t=272702
2006 Toyota Tacoma double cab 4x4
PipsC10 is offline   Reply With Quote
Old 05-30-2008, 02:40 PM   #15
caminokid
Chevy nut
caminokid's Avatar
Re: Disk Conversion
I have gutted out two trucks to get my 5 lug set up. I dont even have 150.00 in all my stuff. My rear axles are 77...with the brakes and backing plates...and my whole front suspension is 87. I also used the 87 power steering box and pump.
The good thing about this is...if you buy it cheap enough...you can sell off parts and scrap the rest and get your money back.
84 Chevy Custom Deluxe 1/2 Ton Named Fade To Black II
"Remember kids there is NO replacement for displacement!"
caminokid is offline   Reply With Quote
Old 05-30-2008, 02:42 PM   #16
FormerMember
Re: Disk Conversion
Yes, I have done similar things. Right now, I am in the middle of more than four projects. Don't want another one.
