bodydrops!-steering shaft
ok ive got it all down on how i believe im gonna do a body drop but ive always wondered how you get your steering shaft to line up with the gearbox. do you put a u-joint in it or what? thanks for the info
1972 chevy long bed. Currently under construction!! Bagged, 383/700r4. |
Fabricate till you "puke"
Mine is a minor drop(1 1/2 "), so I didnt have too much trouble, just egged the holes in the hanger under the dash, & adjusted it.........
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
