Old 05-30-2008, 02:11 PM   #1
Darkblu
Darkblu's Avatar
VIN/What do I have pt2
As some might remember form my original post http://67-72chevytrucks.com/vboard/s...d.php?t=293543 I am not sure what this truck might be so I have added a few more pics to help figure it out. Any and all help will be greatly apperciated. Thanks Frank.
Darkblu is offline   Reply With Quote
Old 05-30-2008, 02:37 PM   #2
Re: VIN/What do I have pt2
Your jamb-plate has been swapped.I think that is all.Prolly a title problem,so they switched it.It doesn`t even look like it`s been painted,or is painted back in original color.I don`t see a mix of trucks there.What number is on the SPID?Does it match the frame?IThat`s not a complete number on the frame.Everything indicates it`s a`71 C2500 that has just had the I.D. changed...and motor.
Old 05-30-2008, 02:43 PM   #3
Darkblu
Darkblu's Avatar
What is the SPID?
Old 05-30-2008, 03:13 PM   #4
SPID is the label in the glove box. IT looks to me like the frame and the cab/body are from two different trucks. Like Special K said, someone swapped something around whihc is quiet common for these trucks. Takes parts from several vehicels to put one back to life.
Old 05-30-2008, 03:22 PM   #5
Darkblu
Darkblu's Avatar
Ah, well here is the SPID. CE334-ZZ62533. I have a pic but dunno how to add it.
Old 05-30-2008, 04:18 PM   #6
nightmare
nightmare's Avatar
next to the Post Quick Reply is Go Advanced. In there there is an option to Manage Attachments. That will bring up the main window for you to add the pics.
Mike
2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip
1972 Chevy Suburban - Turquoise/Black
1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD
Using your turn signal is not "giving information to the enemy"
67-72 FAQ
Originally Posted by GMCMAX View Post
My lugnuts require more torque than your honda makes!
nightmare is offline   Reply With Quote
Old 05-30-2008, 04:59 PM   #7
Darkblu
Darkblu's Avatar
K, thanks
Old 05-30-2008, 05:10 PM   #8
Willys47
Willys47's Avatar
the vin tage may have been from another truck and riveted on?Dont they have a flower shape rivet.
I was hooked on these trucks since 1982 when I drove my budys fathers 1968 Custum GMC 396 automatic dana 60 rear with a power lock diff what a ride more fun then we will we can ever tell!!
Willys47 is offline   Reply With Quote
Old 05-30-2008, 05:21 PM   #9
Darkblu....looks like you got three (at least) different vehicles there since the SPID doesn't match the cab or frame#
Old 05-30-2008, 05:28 PM   #10
Darkblu
Darkblu's Avatar
Thats what I was thinkin. This thing must be a Frankenstein. The title matches the one on the door frame, and the title reads 1970, so who knows. Are there just the 3 places VINs are located? Maybe I can find a 4th #, and it be different.
Old 05-30-2008, 07:57 PM   #11
nightmare
nightmare's Avatar
The title's probably the best one to go with. You can always reproduce the SPID, and then add what it is you want on there. By the looks of the SPID on the door, it looks like it was a nicely optioned truck (where ever it came from).
I don't think that there are any other places for the VIN's
By the way, I noticed that the doors have the Custom Camper script on there. Are you planning on removing them?
Mike
67-72 FAQ
Old 05-31-2008, 04:33 AM   #12
Darkblu
Darkblu's Avatar
I might, not sure what do do with the truck yet. What have other people done to 3/4 or 1 ton trucks? I could use a few ideas.
Old 05-31-2008, 11:51 AM   #13
OhioDan
OhioDan's Avatar
Here's a couple pics of my 70' GMC 2500. Hope this helps?
LIFE AIN'T EASY WHEN YER FAT AND GREASY!
GMC= Got More Class!
1970 GMC LWB, Fleetside, 350/4spd, Flowmaster "40's", 2002 GMC 16" Rallies, cowl hood,and added a bunch of options that weren't there when I started.
OhioDan is offline   Reply With Quote
Old 05-31-2008, 01:20 PM   #14
Darkblu
Darkblu's Avatar
Looks nice , thanks. I like the guages, I have noticed a few trucks that have those type of guages. Thats definitely a custon seat, j/k. Nice lookin motor too, thanks. Its hard to find 8 lug wheels i've noticed.
Old 05-31-2008, 01:53 PM   #15
I think your cab is from a 1 ton CustomCamper(GMC Longhorn).That`s my hunch.The SPID or VIN-spes sheet states it`s a 133" 1 ton.What do your fender badges say,2500 Custom or 3500?Maybe the truck was a CustomCamper/Longhorn that got set on a 127" 2500 frame w/bed.Is the whole truck repainted,just the bed,or none?If none,maybe the guy found a matching 8` bed.
Old 05-31-2008, 02:09 PM   #16
Darkblu
Darkblu's Avatar
It syas 3500, I beleive the whole thing was repainted because of a few overspray in some areas. What is the difference between 1 and 3/4 tons? Is there another way to tell the difference between 127" and 133" other than measuring of coarse?
Old 05-31-2008, 02:53 PM   #17
ksjh1316
ksjh1316's Avatar
There is one other place there might be a vin and that is on a sticker on your drivers door. Most of these are gone by now but you never know mine was still there.
ksjh1316 is offline   Reply With Quote
Old 05-31-2008, 02:54 PM   #18
Darkblu
Darkblu's Avatar
Thanks, I'll check on that.
Old 05-31-2008, 03:39 PM   #19
jorgensensc
jorgensensc's Avatar
I'm going with the SPID is correct for the truck, then they set it on a long wheelbase frame, then they had some sort of title problem, so they switched out the VIN plate on the door jamb so they could get a clean title. Maybe the truck was originally wrecked, so they changed the frame out, then they didn't want a salvage title so they changed out the VIN plate on the door jamb. That is just one theory, nice truck though.
Shawn
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 05-31-2008, 05:00 PM   #20
Darkblu
Darkblu's Avatar
Thanks, that could be a possibility. It needs a CSI treatment or something.
Old 05-31-2008, 10:07 PM   #21
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
have you had it inspected for the title work yet? You may have some issues since none of the VINS match, and the VIN plate has the wrong rivits on it.
Old 05-31-2008, 10:49 PM   #22
Darkblu
Darkblu's Avatar
Yeah I got that taken care of. Some old lady just came out and matched the door frame VIN with the one on the title and filled out a piece of paper which cost me $3.50. Next I have to have the title switch from Indiana to Ohio, but the great state of Ohio is trying to hose me with Ohio state taxes which is a joke. Bought it from a private seller that owns a body shop, but all the BMV associates are convinced its a dealership regardless of what I say.
Old 05-31-2008, 10:53 PM   #23
Longhorn Man
you have to pay taxes on any vehicle you buy regardless of whom the seller is.
You got lucky, but screwed at the same time.
The lady wasn't supposed to charge you to do that. In the last 7 years, i have titled 5 out of state vehicles here in ohio, and never had to pay to have it inspected.
however... she was supposed to stop you with those way wrong rivits.
I guess it was worth the 3.50 then huh?
Old 05-31-2008, 11:04 PM   #24
Darkblu
Darkblu's Avatar
Yup, she was about to look for the one in the glove box, but I caught her and showed her the one in the door frame. She didn't seem to like her job really. I will work it out and have it on the road in a week.
Old 06-01-2008, 12:32 AM   #25
Longhorn Man
Something I am seeing on your truck...
The black wheels just look funny to me. (I know, it's MY problem! )
Imagine them painted white... it'll match the trim on your rig, and only cost a few hrs labor for a quickie, and $10 in wall mart paint.
Something to think about anyways.
It's still 10 times nicer than my pile.
