As the temps keep rising, I'm seriously considering adding air conditioning to my non-air 1984 SWB... I may have located a good donor (1980 with working A/C, heading to the crusher). What all modifications are necessary to accomplish this? Anyone have pics of the differences between the dashes and cabs?
Arrived on a Pale Horse
Re: Adding A/C to a non-A/C Truck...
I don't have any info to share, but sure will follow this thread if you keep it updated. I'm debating the same "upgrade" for my '87. What I do know is the ductwork under the dash is different.
Jason 87 V30 350TBI/400 White w/Boss V-plow 89 R3500 CC SRW |
I would consider an aftermarket approach to adding AC to a non-AC truck. The factory approach requires sheet metal mods to the firewall to accomodate the system differences. You will probably also end up taking most of the dash apart to complete the swap.
i don't have cab pics.but i added aftermarket a/c to an a/c cab.vintage air can fix you up.but,it will cost you over a grand.if you go that route there is a few of us on here that have done and will be glad help.
" Never look up a dead dogs butt." ![]() |
That may be the best approach... I really enjoy having a non-A/C firewall when doing engine work. Do you have any pics of the vintage air unit installed?
Manual Transmission Club
![]() Join Date: May 2008
I just started looking into it but I heard the other day that there is an a/c unit the runs off electrical instead of being belt driven. The advantage being you don’t have the engine drag from the compressor so you don’t lose gas mileage while you’re running it. I believe you would have to put in a power inverter, a second battery and a stronger alternator. But like I said I just started looking into it, I’ll let you know what I find out.
79 GMC Sierra Grande, SWB, Heavy Half If I wanted easy I would just buy a NEW truck! |
Robert Olson Transport
![]() Join Date: Oct 2002
first off the heater box is different and there is a front section you have to bolt up and yo have to make holes to accomodate the studs and bolts there was h oles that had to be made to accomodate the evaporator?? i forget what its called and then theres all the vents and vacuum and the different kick panels and all i started doing this on my 76 years ago but like i have said many times this was my sons truck and when he messed up we scrapped the project and sold it .. i never got it completed but it was a PITA
It'd be alot cooler if you did
I'm using Hot Rod Air. I have not received my order yet as a takes a few weeks to put the kit together. My order was under a grand and it comes with everything. I have a shaved firewall and the only thing sticking through will be the four hoses (A/C and heater hoses).
Old Heap Driver
I'd go with aftermarket. My S-10 will be getting a Vintage Air A/C Heat Defrost setup this winter.
_____________________________ Bryan '99 Silverado 1500, 4.3, 5-speed, reg cab, short bed '50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser. '40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver. |
http://www.classictrucks.com/tech/06...oning_install/
here's a link to an install that classictrucks magazine did on one of our trucks.it's worth reading for anyone considering the installl.i actually refered to it during mine as kinda a guide/manual type thing.i included an old pic i had that everyone seen a hundred times.but, it show's the firewall panel that covers the old heater box.i went with vintage air mainly because of the "sure fit" system.turned out it wasn't as easy as "sure fit" sounds....but,highly doable.and works excellent.
Very nice boatpuller... Thanks for the advice.
