Old 05-30-2008, 08:35 PM   #1
salazar44
65 - Chevy C10
salazar44's Avatar
Upper Driver-Side Alt Bracket
Can anyone suggest a good upper driver side alternator bracket? I have been using a lower mount and now switching to upper.
I have headers and so far can only find the arm. ARM Link , but im sure there is more needed to mount it up.
Thanks!
VIC
One Repair Leads to Another!
http://vix65chevyc10.blogspot.com
salazar44 is offline   Reply With Quote
Old 05-30-2008, 09:23 PM   #2
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
Re: Upper Driver-Side Alt Bracket
the alternator bolts to the lh exhaust manifold, it also uses this lower bracket ,that goes from the bottom front of the altenatoe to the head.
If you have headers, and or modern heads without the bolt holes tapped in them, you will need to create your own lower bracket.
Old 05-30-2008, 09:35 PM   #3
salazar44
65 - Chevy C10
salazar44's Avatar
hmm.. Im using the flowtech headers. Im sure someone already makes a bracket for the complete setup. Thanks!
VIC
Old 05-30-2008, 09:38 PM   #4
jchav62
1962 C-10
jchav62's Avatar
Are you running a short or long water pump? I run a LWP and I have the 70's-80's set-up with the alt on the upper passenger side...
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 05-31-2008, 02:20 AM   #5
Anthony Fremont
Anthony Fremont's Avatar
My truck came with this modified bracket, it only needs head accesory holes:
Anthony Fremont is offline   Reply With Quote
Old 05-31-2008, 02:44 AM   #6
LILRED66
LILRED66's Avatar
Mr. Gasket makes an upper alternator bracket, as well as a lower bracket, for both stock exhaust manifolds and headers. I have used both and they work well. I don't have any close-up photos, however you favorite local auto parts store (flaps) will have the line of Mr. Gasket engine dress-up accessories.
LILRED66 is offline   Reply With Quote
Old 05-31-2008, 05:46 AM   #7
PrerunnerRob
PrerunnerRob's Avatar
The top one bolts to the header studs, and the lower bolts to that and the alternator
http://www.partsamerica.com/productd...egoryCode=5008
PrerunnerRob is offline   Reply With Quote
Old 05-31-2008, 11:52 AM   #8
rickf
rickf's Avatar
The bracket in Anthony Fremont's pic is available regularly on Ebay. I got one for about $25.00 including shipping, for both the cast bracket shown and the top "adjuster" arm.
By the way, the one in the pic above it broken, or at least modified. Actually, I suspect modified. There should be two of those arms that stick up with the holes for mounting the alternator to the bracket. It looks to me like someone along the line cut off the rear one, probably to fit an alt that had a longer mount than would fit in the stocker.
Here is a pic of one, from a current ebay auction.
Starting bid $9.95 and zero bids as of this writing.
Item # 190225750124
rickf is offline   Reply With Quote
Old 06-01-2008, 03:41 AM   #9
ValveTubeHead
ValveTubeHead's Avatar
For those with swp and w/o pwr steering, the mr. gasket lower mount works like a charm. I struggled with the typical 'upper' header brackets sold everywhere.
fyi: 44" v-belt
ValveTubeHead is offline   Reply With Quote
Old 06-01-2008, 09:44 AM   #10
salazar44
65 - Chevy C10
salazar44's Avatar
nice engine! nice pic! i couldnt figure out how/where to mount the timing tab. holes on it didnt match up with anything on the cover.
VIC
Old 06-01-2008, 04:35 PM   #11
ValveTubeHead
thanks...,
just finished crate motor swap on my '65 last weekend, took lots of photos along the way.
Old 06-01-2008, 09:22 PM   #12
salazar44
65 - Chevy C10
salazar44's Avatar
Valvetubehead... Im not 100% positive, but I think a washer goes in between the alt bracket and the block. I previously didnt have it like that and I think that is how the bolt cracked.
Anyone else chime in on that one.
Anyway, I decided to stick with my lower alt brack (same as valvetubeheads). I FINALLY got the broken bolt out and put it back together.
VIC
Old 06-01-2008, 10:16 PM   #13
joe231
joe231's Avatar
so, i'm guessing you don't have power steering?
CHEVY ONLY
Old 06-01-2008, 10:40 PM   #14
ValveTubeHead
I followed the instruction sheet:
http://www.mr-gasket.com/pdf/5179.pdf
pulley alignment looks good
