Old 05-30-2008, 10:09 PM   #1
cochino12
It followed me home?
cochino12's Avatar
still bouncy?
My k5 has a flip kit in the rear w/stock leaf springs (5 pack), 3" drop coils and 3" lca's, and new bell tech shocks all around. The ride is ok but it's seems to be really bouncy still? anybody else have the same problem? Every other truck I've owned rode rough, any suggestions on getting the bounce out?
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 05-30-2008, 10:44 PM   #2
69BBsuburban
Right in front of you.
69BBsuburban's Avatar
Re: still bouncy?
How close are the bump stops???? Mine was rough too, as it was hitting the stops when hitting small bumps.....trimming a little off made a huge difference....shorter shocks with heavier dampening would help too. I had some Toxic shocks on my blue '80 and it rode nice....
Or you could C-notch the frame....
Pinstriping by Josh
'78 Chevy Silverado SWB (lowered, 454)
'90 Chevy Sport Truck
'68 Dodge Charger R/T
1930 Ford Model A
69BBsuburban is offline   Reply With Quote
Old 05-30-2008, 10:45 PM   #3
westie 666
westie 666's Avatar
Re: still bouncy?
get a suspension shop to check your setup, could be that you have the wrong shocks.
77 Cheyenne no longer in bits
westie 666 is offline   Reply With Quote
Old 05-31-2008, 03:17 PM   #4
LONGHAIR
Re: still bouncy?
Bouncy? or stiff? there is a huge difference.
Is the whole truck "bouncing" or is it just you in the seat?
The truck bounces from "soft" suspension that lacks dampening.
The passengers bounce in the seat from stiff suspension (banging or riding-on the bump stops)
LONGHAIR is offline   Reply With Quote
Old 05-31-2008, 03:30 PM   #5
cochino12
cochino12's Avatar
Re: still bouncy?
its definitly not stiff, it kind of drives like an old cadillac that needs shocks.
Adam
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
Old 05-31-2008, 05:08 PM   #6
LONGHAIR
Re: still bouncy?
Shocks? It sounds like they are too soft...are they adjustable?
Mounting position makes a difference in their effectiveness too. The closer the shock is to being aligned with the direction of wheel travel, the better it works. I have seen some set-ups where the shock mounts are moved "off-line" to allow them to fit. Meaning, a shock that is too long, could be used...but it's effectiveness compromised.
