Old 05-30-2008, 10:31 PM   #1
soba_03
soba_03's Avatar
Wtt: Sbc Parts For Carb & Intake & Cntr Bolt Valve Covers
OK folks I find myself in the middle of a project and in a quandry.
I'm building a 355 and have all the parts I need except Carb intake and valve covers.
Here is what I have up for trade
85 corvette block and heads, TPI Manifold If there is interest I'll provide casting numbers. The heads off this motor are 64CC if I remember correctly, I'm going to strip out the valves and springs.
The block is good it has 80,000 on it and with need cylinder bore checked, it didn't have any problems smoking or blow by. I will need boiled out been sitting a while, I know that thee crank is good (cast) and none of the bearings were bad on rods or mains. I'm also using the rods from this motor for my 355. The TPI Manifold is all there and I believe I even have the ECM and all the wireing.
Also I have 350 .030 over that has been dipped and checked it's a 2 bolt that is sitting in the shop. It's 88-95 block, I had it punched so it's never been run. Again it's just the block and main caps.
HERES WHAT I'M LOOKING TO GET:
I'm looking for 500 - 650 4 barrel and intake manifold for a small block.
I also need a set of center bolt valve covers for a small block.
THIS IS A SMOKING GOOD DEAL FOR SOMEONE...
I'M IN LOUISVILLE AREA IF THERE IS INTEREST I WILL SEND UP THE CASTING NUMBERS.
Just loking to trade some of the stuff I'm not going to use for stuff I'm in need of..
Thanks.....
soba_03 is offline   Reply With Quote
Old 05-30-2008, 10:55 PM   #2
jkaylor68gmc
jkaylor68gmc's Avatar
Re: Wtt: Sbc Parts For Carb & Intake & Cntr Bolt Valve Covers
what do you want for the block that is ready?
1947 International KB-1
1957 Chevy Bel-Air riding low
1962 swb fleetside
2002 Chevrolet Silverado 7-inch lift on 35 Daily driver
2016 Chevy Tahoe Better halves ride
jkaylor68gmc is offline   Reply With Quote
Old 05-30-2008, 11:00 PM   #3
soba_03
soba_03's Avatar
well i was kinda hopeing to trade for parts I needed. So not quite sure. Make me a reasonable offer if you don't have any of the stuff I need.
Regards!!
Old 05-31-2008, 02:43 PM   #4
soba_03
soba_03's Avatar
no interest? Make me an offer?
Old 05-31-2008, 06:17 PM   #5
49m
49m's Avatar
i have some center bolt vavle cover taht can be painted what ever color you want
My Rides
1969 Mustang gt coupe
1971 Chevy Cheyenne
1986 Iroc camaro
1986 K10 Short Bed
1987 Iroc Camaro
1990 rs Camaro
1992 350 ss truck
1998 Honda Civic
2005 Ram 2500 Cummins
My Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=279831
49m is offline   Reply With Quote
