Old 05-30-2008, 11:45 PM   #1
Frosty
Under desk
Frosty's Avatar
Removing 3 inch body lift.
I am removing the 3 inch body lift from the GMC. I need to know the blot size and length of bolts I need to put it back to the frame. Also is there any kind of rubber that should go in between or is it just metal to metal?
Thanks again for being my go to guys!
Frosty
(long part of the story) The previous owners didn't do it right so I'm trying to fix it and make this truck right. I guess they put on a suburban kit on the truck. So I have rubber pucks holding the bed up instead of blocks. It will still have the 4 inch suspension lift and will have to do something about tire rub but I put an end to the body roll.
Frosty Smith 1979 GMC 1/2 ton 2wd diesel that now has a 1976 Firebird V8 engine and is a 4X4 with a 7inch lift.
The real question is would I have still bought it if I had known all this...
Frosty is offline   Reply With Quote
Old 05-30-2008, 11:52 PM   #2
Frosty
Under desk
Frosty's Avatar
Re: Removing 3 inch body lift.
Looks like the Home depot buy the bolts yourself things is a bad idea. LMC has Complete Mounting Kits that seem like the smarter thing to do? Right???
Old 05-31-2008, 05:36 AM   #3
us111
Hello,sorry,know nothing about it myself
but if you haven't already check with the
guys on the 4x4 forum here.they can probably
tell you everything you need to know.
us111 is offline   Reply With Quote
Old 05-31-2008, 06:17 AM   #4
DESTRO
Hello,Hope I can help.
Use grade 5 bolts.You can get those cheaper at a tractor supply if theres one close by. As for the size I cant remember but take one bolt out and measure it then subtract 3". The lift pucks are supposed to sit on top of the factory mount. If those are missing you'll have to purchase them at LMC or I've got them at the dealer pretty reasonable in the past. Don't forget to shorten your shifter linkage [if auto] You have to weld in a piece when installing the body lift.
DESTRO is offline   Reply With Quote
Old 05-31-2008, 07:04 AM   #5
84 400
Sb 400 club
84 400's Avatar
"". Also is there any kind of rubber that should go in between or is it just metal to metal?""
Yes their is. You could also look into polly busings. Tractor supply is the way to go if there is one close as stated above. cheaper then HD. IF it was me i would play around with the hangers or just get a 6inch leaf springs to avoid cutting up the body but that is me. Also did your truck used to be two tone black with a white middle section and a white roof?
Hope this helped.
1984 chevy c10, built 400sb,.(SOLD)
77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363
1956 Willys Wagon (327 chevy) Project (Now Buick 225)
1980 Corvette L-48 4 speed
1992 Mustang GT built 5.0 5 speed
1985 C10 LWB Sold
1982 K10 SWB plow truck Parted out
1986 D30 M1028 fire brush truck Parted out
84 400 is offline   Reply With Quote
Old 05-31-2008, 07:40 PM   #6
Frosty
Under desk
Frosty's Avatar
Yeah, I will check out Tractor Supply. Very good idea/advice! Thanks.
