Old 05-31-2008, 12:44 AM   #1
1970pelle
1970pelle's Avatar
Carb trouble!
My truck has been running quite well for a while.I'm getting decent MPG's.But the last couple of days smelled fuel.Removed carb to look,because of small puddle on the intake.Found this crack in the base plate at the P/B port.I don't think this was my current issue,but a hidden one.
1970pelle is offline   Reply With Quote
Old 05-31-2008, 03:09 AM   #2
PhilaTruck
Right on the line, baby!
PhilaTruck's Avatar
Re: Carb trouble!
Any change in performance after you noticed the puddle/smell?
83 GMC 406 th400/3.73 Eaton Truetrac posi, headers, x pipe, & racePros. Tubular control arms, lowering rear springs, caltracs. Still ugly, but getting built right, although slowly
Click and scroll down for site vendors!
Subscribe here!
PhilaTruck is offline   Reply With Quote
Old 05-31-2008, 12:53 PM   #3
1970pelle
1970pelle's Avatar
Re: Carb trouble!
On cold start ups it had developed a fast idle.It would settle down in 2 miles from the house.
Old 05-31-2008, 02:18 PM   #4
babyJay
Arrived on a Pale Horse
babyJay's Avatar
Re: Carb trouble!
how'd ya do that? What kind of carb is it?
Jason
87 V30 350TBI/400 White w/Boss V-plow
89 R3500 CC SRW
babyJay is offline   Reply With Quote
Old 05-31-2008, 03:06 PM   #5
1970pelle
1970pelle's Avatar
Re: Carb trouble!
Its the Q-jet from my 86 C10.Its the first time I have ever had the carb off.
Old 05-31-2008, 08:42 PM   #6
1970pelle
1970pelle's Avatar
Re: Carb trouble!
I tore the Q-jet down today,found lots of dirt,crud,ect.Also loose parts.Found that the cracked base plate is cracked clear through.I have that feeling this repair is going to keep building into something bigger than I want right now.
Old 05-31-2008, 10:12 PM   #7
COMP
Re: Carb trouble!
check the main body to see if it worped
COMP is offline   Reply With Quote
Old 05-31-2008, 10:50 PM   #8
spudz
spudz's Avatar
Re: Carb trouble!
jb weld it....
2004 z71, 96 z71 on 38s, 88 Chevy k5 blazer, 4in lift. 84 swb project, 82 SWB project , 84 chevy 4x4 lwb project, 88 Jimmy beater/highschool ride. 79 c30. 99 tahoe 4x4 project. and a bunch of parts trucks..
spudz is offline   Reply With Quote
Old 06-01-2008, 12:32 AM   #9
LONGHAIR
Re: Carb trouble!
From the looks of that crack, it came from over-tightening the vacuum fitting. Tapered pipe threads into aluminum that is not much thicker that the thread diameter itself. That is probably more common than we know.
LONGHAIR is offline   Reply With Quote
Old 06-01-2008, 12:36 AM   #10
COMP
Re: Carb trouble!
still check the main body
Old 06-01-2008, 03:57 AM   #11
PhilaTruck
PhilaTruck's Avatar
Re: Carb trouble!
I think you're right on, Longhair.
Sounds like the choke is off. Leaner = faster idle.
You could use a rebuild or replace at this point. It's only been 22 years, or at least it looks like it from that butterfly.
I would replace b/c of the crack, but that's just my $.02. I just don't like cracked carburetors.
Subscribe here!
