Replacing Power Window Switch
Does anyone have a tutorial on how to replace this switch? My drivers side switch went out today.....glad the window was rolled!!!!
84 C-10 Want a free xbox 360 elite go here to see how http://geocities.com/razorbackfan90/ |
Robert Olson Transport
![]() Join Date: Oct 2002
Re: Replacing Power Window Switch
well pop off the door panel there is a screw on thing holding on the wires and then you compress the clips on the switch and pop it out install is reverse of the above
you can prolly reach it if you unscrew the door panel and reach up
Sb 400 club
Old rusty has got it! and i was suprised to find that in the help section of stores like advance auto they sell our switches. I bet the quality is lower then GM. I get my from the bone yars
1984 chevy c10, built 400sb,.(SOLD )77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363 1956 Willys Wagon (327 chevy) Project (Now Buick 225) 1980 Corvette L-48 4 speed 1992 Mustang GT built 5.0 5 speed ![]() 1985 C10 LWB Sold 1982 K10 SWB plow truck Parted out 1986 D30 M1028 fire brush truck Parted out |
Cool I'm going to get this done today thanks for the help!
Well the switch is not the problem. I removed the old switch and put in the new one no luck driver side window will still not go down....any tbshoot ideas?
The first thing I would to is "hot wire" the motor, to be sure it works.
You will have to take the door panel apart, to gain access to the motor, for the rest of this. The connector that plugs into the side of the motor has 2 wires. In "normal" position of the switch (centered = off) neither of these wires is hot or grounded. The motor itself is insulated from ground too. Make yourself a "temporary" harness.... two wires with female "spade" connectors. Plug them into the motor and touch them to something like jumper cables or a battery charger. (Not directly to a battery, this can cause a spark/explosion) One goes to "hot 12v" and the other to ground, it doesn't matter which is which. If nothing happens...reverse the wires. One way is up, the other down. If you get nothing either way, the motor itself is bad. I never assume that "new" parts are good...your switch in this case. Being sure that the motor itself works is key to trouble shooting. This is even more complicated on the passenger's side because there are two switches that make it work. Taking the switches, wiring, fuses, relays, etc out of the mix will steer you in the right direction. |
ive had two of these things have bad grounds on the olds cars back in the day for some reason ive never had power windows in a chevy truck but im betting the system is similar
Hmmm good advice thanks. The weird thing is I can tap (hard) on the door panel (just above the handle to open the door) while holding the switch and it will go up and down but it's kind of jerky when it does.
i had a caravan that had a similar problem and it was the stupid gear inside the motor
| Bookmarks |
