Old 05-31-2008, 01:07 AM   #1
avysittinon22s
avysittinon22s's Avatar
What kind of air line fittings to use?
Wondering what the best type of air line fittings to use on my air bag suspension?
avysittinon22s is offline   Reply With Quote
Old 05-31-2008, 01:17 AM   #2
scotts62
One day...
scotts62's Avatar
Re: What kind of air line fittings to use?
I wouldn't use the press in kind or ''quick connect'' I would only use the brass. (And i cant remember the exact name for them.....someone help me out..)
Thats just my opinion, i have had friends where the (quick connect) fittings have left them stranded in traffic at an intersection because they leak really bad or pop out.
Scott,
Scott
93 crew cab build
Project 62
Old 05-31-2008, 01:45 AM   #3
TravRMK
TravRMK's Avatar
brass compression fittings.
TravRMK is offline   Reply With Quote
Old 05-31-2008, 02:27 AM   #4
jlaird
jlaird's Avatar
Scott,
It's all in the installation my friend. PTC, compression, they all work well. Just make sure they are DOT.
jlaird is offline   Reply With Quote
Old 05-31-2008, 05:40 AM   #5
scotts62
One day...
scotts62's Avatar
Yep i agree 100%, that was just in my opinion.
Scott
93 crew cab build
Project 62
Old 05-31-2008, 06:15 AM   #6
Shane
Shane's Avatar
DOT approved Push To Connect fittings are perfectly fine if one knows what they are doing and then takes the time to properly prepare the TUBING before making up the fitting. Emphasis on "knows what they are doing."
Take a peep under most any over-the-road truck and see what kind of fittings they use on their bags and even some on their air brake systems ... you guessed it ... Push-To-Connect fittings.
Shane is offline   Reply With Quote
Old 05-31-2008, 07:25 AM   #7
red02chevy
Eaton Weatherhead PTC's
red02chevy is offline   Reply With Quote
Old 05-31-2008, 07:57 AM   #8
Frizzle Fry
Frizzle Fry's Avatar
I'm going to switch over to swagelok compression fittings when I change over to 1/4" copper line. Right now I have PTC (aka one-touch).
Frizzle Fry is offline   Reply With Quote
Old 05-31-2008, 01:55 PM   #9
tds
http://www.fastenal.com/web/products...=441030-131280
like these?
1981 - C-10 SCSB
Planning on putting this thing on it's rocker!
tds is offline   Reply With Quote
Old 05-31-2008, 02:21 PM   #10
scotts62
One day...
scotts62's Avatar
Again that was just my opinion
Scott
93 crew cab build
Project 62
Old 06-01-2008, 07:22 AM   #11
randomhero472
randomhero472's Avatar
Originally Posted by tds View Post
THIRTY FIVE DOLLARS........
67' in the "build" process.. soon to be bagged, big wheels ect, finally got it back home!!
randomhero472 is offline   Reply With Quote
Old 06-01-2008, 06:58 PM   #12
project1968
project1968's Avatar
Hey Shane, What is the correct way to prepare fittings for the quick connect?...are you talking about a clean, straight cut with a sharp razor blade or is there more
project1968 is offline   Reply With Quote
Old 06-02-2008, 03:16 AM   #13
tds
i'd order them through work and not pay that price
1981 - C-10 SCSB
Old 06-02-2008, 09:23 AM   #14
Shane
Shane's Avatar
clean square cuts to the tubing (i use one of these) . The one shown comes from Harbor Freight and is about 1/10 the price of the one I ordered from McMaster-Carr a few years back. I have since picked one of the HF cutters up and it works just as well.
Depending on the tubing, but sometimes you will need to "debur" the cut-end O.D. with some sand paper. Not enough to change the round shape of the tubing, but just enough to remove the "burr"
Good Luck.
Old 06-02-2008, 07:27 PM   #15
project1968
That is a very cool tool. I put bags on the rear with schrader valves and I made the cuts very carfully trying to be straight and I used a new sharp razor blade, but I have a very slow leak on one side and I think I have tracked to be one of the quick connects where the tubing goes in. I wonder if I can try to redo the connection with the same QC fitting?
Old 06-02-2008, 10:33 PM   #16
Shane
Shane's Avatar
push to connect fittings are designed to be reusable ... I use a open end wrench the same size as the tubing (3/8" in my case) and then place the open-end portion of the wrench so it is "straddling" the tubing, then push down on the ring with the wrench while gently pulling on the tubing.
It should pull right out. You can then trim it and then push back in to make your connection.
FWIW: I have had more trouble getting the NPT (threaded) portion of the fittings to seal than I have the PTC portion.
P.S. soapy water in a squirt bottle will help pin point the leak ... cheap too.
Good Luck.
Old 06-02-2008, 11:27 PM   #17
project1968
Thanks for the info, I will br working on it this weekend
