05-31-2008, 01:33 AM | #1 |
loose front end
what could be done to tighten up the front end of a 1972 c10? i have replaced both upper and lower ball joints. everything else passes inspection yet it still feels loose.
05-31-2008, 01:54 AM | #2 |
Re: loose front end
You mean loose as in steering wander or is it making sounds like something is loose?Control arm bushings shot
Steering gear way loose Tie-rod ends AFU Idler or pitman loose Wheel bearings STH or just loose Allignment way off Tires wore funny from bad allignment Rear axle loose causing weird trust angle during accelleration I'll think of more later,but did you check all these?
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme. Last edited by WorkinLonghorn; 05-31-2008 at 01:56 AM. |
05-31-2008, 10:30 PM | #3 |
Registered Mail
Re: loose front end
not trying to jack the thread, but it is related...
How much play is considered normal in the control arm bushings?? for example I have my spindles off and when I move each control arm i feel and see a slight movement when pushing side to side.. is this still ok? basically is moves just enough to detect actual movement.
'67 chev 496, lwb to swb, bagged - pro street project |
05-31-2008, 10:33 PM | #4 |
Re: loose front end
the bushing are rubber so there will be some flex.If you see any cracks in them go ahead and replace them.m.lander have you checked the play in your steering gear?
05-31-2008, 11:30 PM | #5 |
Gone to greener pastures
Re: loose front end
This might help.
Find a helper. Have them "rock" the steering wheel. Follow all of the steering components (tie rod ends, drag link, idler arm, etc) from the steering box to both spindles to see what is, or isn't moving as it should. It seems to work real good for the Highway Patrol when they're inspecting them big rig, trailer trucks.
'69 Chevy 1/2 T LWB Stepper: Daily Beater '72 GMC 3/4 T Fleet: Another Daily Beater '72 Plymouth Gran Coupe: ? "Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche "Never kick a fresh turd on a hot day." Harry S. Truman GUN CONTROL: Never having to say, "I missed you." Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck |
06-01-2008, 01:00 AM | #6 |
Who's got steelies?
Re: loose front end
If he's switched to the 73 and up, then yes, but the control arm bushing on 67-72 are all metal with rubber dust boots. I replaced the bushings and pivot shafts a couple summers ago and it is all metal to metal. The bushings actually screw into the arms, and onto the shafts.
1969 C10 LWB W/ 250 I6 & 3spd 1970 C10 with '67 small window cab, 68 front end, blue; 305/TH350, 3.08 limited slip rear end, manual brakes, power steering; & 4-wheel drums-My daily driver. 1975 Chevelle Malibu Classic Coupe 350/th350 mint green 1970 C20 Suburban 350/700R4 4.10 gearing green & white 1978 Big 10 Silverado 350/th350, working ac, 2 tone blue-My summer daily driver 1983 GMC 1500 Sierra 305/SM465 2.73 rear end How to add a trip odometer to your 67-72 stock speedometer How to rebuild your Q-Jet My Truck Page My Youtube Channel |
06-01-2008, 02:26 AM | #7 |
Rolled on Paint Club
Re: loose front end
I discovered I had a little play in my steering after putting the truck back on the road and it turned out to be in the below pictured joint in the column. I havent figured out what to do about it yet. Also check your rag joint.
Bob
1970 GMC 1500 swb fleetside SB 355ci. Smog heads Summit 1102 cam Performer intake and carb. Finally in about 1 piece in the yard. |
06-01-2008, 02:46 AM | #8 |
Re: loose front end
Sometimes you get play inside the gear box. And I believe there is a adjustment with a screw for them too. Rag joint is a bit lower on the pic. If you have play that high it is in the lower shaft caused from not having it tight alowing the clamp to work loose. That would most likely need to be replaced. Worn shaft.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
06-01-2008, 10:52 PM | #9 |
Re: loose front end
Put a jack under each lower cotrol arm. Grab the wheel in different possitions & push & pull. No bushings or joints should have should have any play in them. Have someone turn the steering wheel back & forth about 2 inches. Watch the joints in the linkage especially the pitman arm.
06-01-2008, 11:40 PM | #10 | |
Re: loose front end
06-02-2008, 01:56 AM | #11 |
Re: loose front end
worn out suspension will let the truck wonder a bit but if youre talking about a shake then make sure your wheel bearings are packed good and tightened up
-steven Alte Seele S.S. "Allison" '72 C/10 LWB 350SB/TH350 - DD PITBULL IS NOT A CRIME |
