Old 05-31-2008, 02:10 AM   #1
slick78
454 engine
so im replacing the straight 6 and three speed trany on my 1978 stepside.with a 454 and th400.can anyone tell me what parts do i have to get to complete this.like wiring harnes and stuff like that.i would really appreciate it.
slick78 is offline   Reply With Quote
Old 05-31-2008, 03:24 AM   #2
PhilaTruck
Right on the line, baby!
PhilaTruck's Avatar
Re: 454 engine
Is the 454 injected or carbed?
Is the current 3 speed auto or manual?
Some other stuff you may not have thought of: radiator, driveshaft, various linkages & of course motor mounts.
I haven't done a swap like this, but lot's of members have.
We're gonna need more info to help.
83 GMC 406 th400/3.73 Eaton Truetrac posi, headers, x pipe, & racePros. Tubular control arms, lowering rear springs, caltracs. Still ugly, but getting built right, although slowly
Click and scroll down for site vendors!
Subscribe here!
PhilaTruck is offline   Reply With Quote
Old 05-31-2008, 11:47 PM   #3
slick78
Re: 454 engine
its carb,with a manual three speed.but im changing to automatic floor shifter.so i gota change drive shafts too.im adding power sterring,new radiator.and im going with a comp cam a 230/230 @50 with a edelbrok air gap.and a holley 750.what u guys think about that combo?
Old 06-01-2008, 06:02 AM   #4
87Lowrider
Navy Radioman Veteran
87Lowrider's Avatar
Re: 454 engine
With the exception of the cam, that's the engine I put in mine. I started with a 350 though. The cam I'm using is a Xtreme Energy 552/550 286 dur. I had the heads opened up with 2.190's / 1.880's too... It's a nasty combo, sounds great. Of course, I put all MSD on it, electric fan, 700R4. Don't know how accurate but Desktop Dyno says 451hp/502ft lbs @ 5500. Workin' on Bags now before I put it back on the road.
87Lowrider is offline   Reply With Quote
Old 06-02-2008, 06:28 PM   #5
slick78
Re: 454 engine
so u think its a good combination or not? what u guys think of the cam? should i get a different one.i want power and something that sounds good.is that cam fine?
Old 06-02-2008, 11:02 PM   #6
87Lowrider
87Lowrider's Avatar
Re: 454 engine
As far as the engine.. depending on how you want it to perform, you can build it like you have it or pump it up a bit. Mine is just mild. www.compams.com has a section where you can listen to their cams.
Kenny
Old 06-03-2008, 03:16 PM   #7
slick78
Re: 454 engine
ill check out the web site.but what do u guys think what combo should i get? the one i have or what should i get?
