Old 05-31-2008, 03:53 AM   #1
prg machine
prg machine's Avatar
dual horns
My truck originaly just had the one horn but i found a truck at the pick-u-pull yard that had dual horns and I grabbed em and the wiring harness was good so I have that in my truck.
Does someone have a picture of how the 2 horns mount up?
69 K-20 cloned to a 67 with front clip and some other stuff.
383 .040 over
Crane roller cam lifters and rockers ,1.6 intake ratio, Open chamber heads, 9.5-1 compression ratio, 2.02 intake valves , Edelbrock performer Air Gap manifold Carter AFB performer 750cfm, MSD ignition, SM465 NP205 4.10 gears:
prg machine is offline   Reply With Quote
Old 05-31-2008, 04:06 AM   #2
Sammy
Re: dual horns
No Pic but it is plain & simple. Dual horns usually are high pitch & low pitch. The electrical connector pigtail has a piggy back jumper connector from the one horn to the other. Mount the horns and thats it.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 05-31-2008, 04:29 AM   #3
prg machine
Re: dual horns
sammy..............I pretty much got the wire correct if the green ones are for the horn. I was more interested in exactly where they mount over there by the voltasge regualator....................It has been 4 years since i pulled em off the other truck
383 .040 over
Old 05-31-2008, 04:42 AM   #4
Botietruck
'71 chevy s.bed/s.side
Botietruck's Avatar
Re: dual horns
Here's a set, that left horn should probably be positioned down just a bit.
STILL PLAYS WITH CARS...AND TRUCKS!!
Parents! Be good to your kids...they get to choose your nursing home!
250 I-6 with a 3 speed Saginaw and Borg Warner Overdrive...She's got overdrive!
Botietruck is offline   Reply With Quote
