Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 05-31-2008, 06:58 AM   #1
Super73
Super73's Avatar
Should I put the turbo motor set up in the truck?
So, I will probably be getting my Camaro back in the next 3-6 months. I'm going to take the motor out of the truck and run it in the Camaro for a while to dial in suspension and just get a feel for it.
The motor that I have sitting for the Camaro is a 8.5-1cr AFR headed solid roller built to handle over 1000rwhp and spin to 8,200 that will be topped with a PT91 turbo.
By putting it in the truck, I would be able to break it in and learn the Gen 7 software since it will be completely new to me before putting it in the 2,900lb 6-speed road race car. Give me a chance to hammer down on it for a while, pull it apart and check things out before I put it in the Camaro.
Or should I wait to run it until after I test drive the Camaro for a while with the truck motor and just stick it in there?
Hmmmm
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 05-31-2008, 07:08 AM   #2
joeys66pickup
Dr. Frankenstein
joeys66pickup's Avatar
Re: Should I put the turbo motor set up in the truck?
do you really need to ask this question or are you trying to rub it in??
throw the turbo motor in BUT make sure you let us all see the "breaking in"
I Wanna Go Fast!!
joeys66pickup is offline   Reply With Quote
Old 05-31-2008, 09:59 PM   #3
Alex1
Alex1's Avatar
I don't think it's a good idea - send the engine to me instead.
Alex1 is offline   Reply With Quote
Old 06-02-2008, 10:21 AM   #4
Couch
Daily Driver
Couch's Avatar
by even making this post you've wasted valueable time that couldve been used wisely puttin the turbo motor in the truck.
by the way that fox body that came to fresno is pretty damn quick. beat nates cobra by a few, but nate did completly blitz the tires through 3rd.i fell kinda bad for the fox guys,they traveled all that way to blow theyre stuff up
nitrous...the equal opportunity destroyer.
Couch is offline   Reply With Quote
Old 06-02-2008, 12:39 PM   #5
PA-IndianRider
PA-IndianRider's Avatar
Hmmmm
Hmmmmmmm..... must be nice to afford to have the time & resources to do what you're planning to do.
I do have a better idea.... I have a C10 in my backyard that you could.....ha!!
Good luck....either way is a WIN - WIN ..... you rock!!!!
John - Pittsburgh
John aka "Milner"
PA-IndianRider - Pittsburgh, PA
70 Chevy C10 Stepside
"Gasser/Altered Drag Race Hot Rod"
Where were You in '62 ?
PA-IndianRider is offline   Reply With Quote
Old 06-02-2008, 06:33 PM   #6
shortbed70
shortbed70's Avatar
put it in the truck....
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
Old 06-02-2008, 07:09 PM   #7
Marv D
Registered Truck Offender
Marv D's Avatar
Of course you should. You do know Horsepower goes stale don't you? If you don't use it, it just sort of evaporates away. If you don't put it to use your going to wind up throwing it out like an ol stale loaf of bread.
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 06-02-2008, 07:37 PM   #8
Alex1
Alex1's Avatar
Old 06-06-2008, 01:41 AM   #9
Super73
Super73's Avatar
Ok.. I think I decided to go and pick up my turbo motor from the chasis guys house. It's been in the Camaro for some time and the car is not finished. I'll grab the Turbo, BOV, WG and manifolds and probably start fabing up the plumbing in the next few weeks.
When Joe is done with the car, The truck will go for a 12 point cage ect.
Now, I'm thinking, this set up is good for well in to the 1000rwhp mark. I'm thinking I will be buying fierglass fenders, hood and front nose pice, take the heavy tailgate off and change a few other things around. Hoping to get it from it's 3,900 race weight to 3,500.
Some of you more experienced guys, I would like to get your feedback on what you think the truck will be capable of at 3,500 and say 1k rwhp.. I need to make sure when I get it to my chasis guy, it can be certed to the number.
Mid low 9's?
Old 06-06-2008, 08:04 AM   #10
Alex1
Alex1's Avatar
9's?
Old 06-06-2008, 08:09 AM   #11
Alex1
Alex1's Avatar
Do you have pictures of your headers? I'm in the process of building some for my 468BB - I have started in mild steel but decided to go with SS - Are you running an intercooler?
Old 06-06-2008, 10:11 AM   #12
Marv D
Marv D's Avatar
Trying to push these bricks through the air to get a low 9 is going to be a major feat. As I'm sure you know 1000RWHP would be a mid/high 8 in any 'normal' race car. If you can keep it hooked for a mid 9 with all that power,,in a heavy@$$ truck like this.... I'd say a big kudos was in order
Old 06-06-2008, 11:09 AM   #13
Super73
Super73's Avatar
I'm going to be running factory C5 Z06 manifolds as they are a tri-y set up and flow better than any other factory set up. I also choose to go with a cast iron manifold due to heat and stress. They are less likely to crack.
Marv, I agree they are heavy, but 3,500lb race weight is that of a stock 4th Gen F-bod. I've seen a couple 3,600lb 6 speed 4th gens run low 9's. Given they have way better aero, I think it can be done with some time.
Old 06-07-2008, 10:11 AM   #14
PA-IndianRider
....... . Given they have way better aero, I think it can be done with some time.
Get out the "hacksaw" and wack about 5 inches off of the roof..... that'll cut down on the "drag".... LOVE "chopped roofs"... but they also make a lot of sense when racing.... just look at the "Bonneville Salt Flats racers"..... But for people like me we don't need any "reasons" to chop.....
John aka "Milner"
