SWB 4X4 CLUB
Rear slider removal
I found a truck in a local yard with a factory slider. What is the easiest way to remove it? Is it as easy as cutting the gasket and poping it out? Anybody with any tips or tricks?
Jason |
#2 | |
Re: Rear slider removal
Start at one of the upper corners and work it out a little at a time. Again, take your time and be patient, use as much soapy water as you can and you'll have it out unscathed. Good Luck. Eric |
I cut mine out with a utility knife. Mine wasn't a slider, but I figure the rubber would be the same. It was easy as can be since I didn't want to keep the rubber.
Jay
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape. If a hammer doesn't fix it, you have an electrical problem! Slot Cars, 1:24 Scale, 100MPH@100,000RPM, fastest things on wheels! ![]() |
SWB 4X4 CLUB
Thanks guys. I am heading out now to give it a try. I will let you know how it works out.
Jason |
blood type; Retumbo
or you can buy them for $30 at a pick-n-pull.
DO NOT use dish soap. it makes it more difficult. use the slimey hand cleaner like gojo. trust me, I learned the hard way. ![]() |
![]() Join Date: Feb 2001
A husband can be right...or...A husband can be happy. ![]() 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. ![]() 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc ![]() ![]() JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
you can buy these new still
Greater love hath no man than to lay down his life for a friend. Members i Have met Earl Slick68 1969 Stepside Build thread http://67-72chevytrucks.com/vboard/s...=1#post4253546 ![]() ![]() |
SWB 4X4 CLUB
the owner said he crushed the truck the day before I got there.
Would like to know where I could buy a new one and what do they cost? Jason |
there is this place where i live that is called doozy and they sell them new i can find out for you
#11 | |
you might find what you need. Eric Last edited by estig70; 06-03-2008 at 11:12 AM. |
