Pics of power steering brackets, please
I'm working on putting p/s on the '66. Any body running p/s with a short water pump, and the alt. mounted to the exhaust. I would like to keep my alt where it is. Pictures would be grand. I have found a bracket online that will work, think I might just fab something up, looking for ideas
here is the one I found bracket linky
![]() ![]() Last edited by joe231; 05-31-2008 at 04:36 PM. |
Re: Pics of power steering brackets, please
what engine we dealing with here?
1961 crewcab
some pics from the files....
283 stuff. |
283 ci
jon, i saw those pics in the other post. my manifolds are different than that second pic that first pic might be helpful, but i can't see the p/s set up here are some crappy phone pics of my alt set up and this looks very similar to the bracket that mounts to the exhaust manifold
![]() ![]() Last edited by joe231; 05-31-2008 at 07:42 PM. |
ttt
Hey Y'all!!
I don't recall exactly which manifolds are on your truck but they appear to be later model ones to me. If so, you will probably have to go with a custom bracket or the (pricey) one that you posted the link for. I don't recall EXACTLY what year the SWP went away but I believe it was around the same time that the Rams Head manifolds went away. So, in short, I don't think GM made a bracket setup for the SWP and the type manifolds that you are running. Keep in mind, this is just my opinion.
yeah, i'm not sure. these appear to be the rams horn manifolds, i think they are era correct but not sure. there is the possibility that they are car manifolds. i will get some better pics.
also my heads have no accessory holes, so that rules out some other options
better pics
maybe Tony (or some one knowledgeable in stock stuff) could shed some light on what these manifolds are out of i'm off to look for some mid 60's-early 70's brackets....wish me luck ![]()
One day...
Hey Joe, did you not have the right bracket the other day?
nope, the brackets i have are for a long pump
One day...
Ya that sucks. I will look for my brackets for you. If not ill be home well make em
My 66 GMC has factory PS, but the pump and bracket aren't installed right now. I'll take a picture of my bracket. It's funky, it uses the front motor mount holes and sorta wraps around the block so that another bolt can go thru the bracket and into the side of the motor. I don't believe that it connects to the exhaust manifold and I'm sure that it doesn't connect to the water pump.
#13 |
i ll have some photos for you tommorrow, i took some today.
#14 |
Resistance is Futile
You have a rare factory option in that heated ground cable..........
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
#15 |
cool, thanks guys!!
protrash, your just jealous, ![]() you like the color too, don't cha? red for ground and black for hot. you have no idea how many times i have tried to hook jumper cables backwards ![]() just one more item on my list ![]()
#16 |
Zombie Killer
1964 C10 Long Step |
#17 |
is that a short water pump????
#18 |
hers shots of my ps stuff
i287.photobucket.com/albums/ll134/orange70_photo/may312008026.jpg[/IMG] Last edited by pquick; 06-02-2008 at 11:23 AM. |
#19 |
60-66 Nut
![]() ![]() Join Date: Mar 2007
If you still need a pic let me know and I'll get you one of the original p/s bracket on my '66 C20. Those exhaust manifolds look to be original to me. I may have an extra set of brackets, I'll have to look and see.
#20 | |
thank you
#21 |
60-66 Nut
PM sent...
#22 |
Zombie Killer
#23 |
![]() ![]() ![]() hope this helps.... |
#24 |
very helpful, thanks
thanks to everyone for all the help ![]() I love this place!!
