Old 05-31-2008, 05:50 PM   #1
jayharrell
Gettin By on Gettin By
jayharrell's Avatar
Rear relocation lines, rubber or steal??
Going to get my burb tank put in this weekend if the weater works right.
Is it that bad of an idea to run just regular old braided rubber fuel line up the frame? Or is steal more sane?? I'm going to run dual exaust and probably dump out right infront or behind the tires on my LWB 69, so i'm alittle concerned about heat getting to the lines.
Anyone have any opinions?? *thats probably the only actuall 'stupid question' on the board* LOL
69 CST10 LWB 455 Buick
00 S10 2.2 Vin5
76 GL1000 Naked 1bl VW carb
"Adios to all the concrete; Gonna get me some dirt road back streets"
jayharrell is offline   Reply With Quote
Old 05-31-2008, 06:46 PM   #2
steelhorse
steelhorse's Avatar
Re: Rear relocation lines, rubber or steal??
I have always prefered steel,but then I am one of those crazy people that upgrades the brakes before the engine.
steelhorse is offline   Reply With Quote
Old 05-31-2008, 07:18 PM   #3
jayharrell
jayharrell's Avatar
I was also thinking about hitting the man mall and yanking a fuel line system out of a 80ish burb, then just retro fit it. Then i would have an inline filter and such.
Any thoughts on that??
00 S10 2.2 Vin5
Old 05-31-2008, 07:29 PM   #4
Jim_PA
I hope to install some Aeroquip socketless hose (no clamps or crimping) this weekend. It's NHRA approved, and sounds like it just might be a little tricky getting the fittings into the hose, but seems like routing the hose should be an easy task.
Jim_PA is offline   Reply With Quote
Old 05-31-2008, 08:05 PM   #5
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
Rubber works perfectly fine as long as you use rubber that is designed for use with Gasoline. Regular radiator flex hose will not work for long. Gas eats right through that stuff. WES
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 05-31-2008, 08:58 PM   #6
fnoblitt
fnoblitt's Avatar
i used aluminum fuel line down the frame rail, easy to work with
70 c10 stepside ,350v8, m-20 4 speed
fnoblitt is offline   Reply With Quote
Old 05-31-2008, 10:19 PM   #7
jayharrell
jayharrell's Avatar
Alright, Thanks Wes. I'll hit AA today.
00 S10 2.2 Vin5
Old 05-31-2008, 10:39 PM   #8
chevy72blu
chevy72blu's Avatar
I would just buy a 20' roll of steel hardline and a cheap bender. Buy some mounting tabs and use rubber fuel hose at the connections. Thats how they made em from the factory. As with any hose clamps, make sure you check on them here and agains for cracking or tiny leaks.
Theres a product called "Cool blue" which is a rubber fuel hose wrapped in a instulating material. It helps to prevent vapor lock and I have been using it for 5+ years and even in tight bends and what not, I have never heard of this stuff cracking. Its tougher to get onto a nipple fitting and its a little pricey, but its a happy medium between plain jane rubber hose and expensive braided/AN plumbing.
RIP EastSideLowLife
'72 C20 SWB convert. 5 lug, LS1/4l60e
chevy72blu is offline   Reply With Quote
Old 05-31-2008, 10:47 PM   #9
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I would go with hardloine.... and no filters between the tank and pump... it can cause or agrivate vapor lock.
Old 06-01-2008, 03:36 AM   #10
Sammy
I used a stainless fridge freon line & rubber fuel line on the connections. Hard to bend but should last as long as a slow poke sucker.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
