06-01-2008, 07:19 PM | #1 |
Project 7dos
3.73 or 4.11??
Hey guys,
We are going to get some new gears + posi. Right now we have 3.08 and no posi, and they are just dogs... My question though is should we go for 373s or 411s? It will see absolutely no highway driving, so that is not a concern, tranny is a th350...
7DOS - 1972 C-10 350/350 Porterbuilt/Accuair 20x8.5/20x10 Ride Low or Die PSSST - Yes it's bagged. 7dos build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=610290 |
06-01-2008, 07:25 PM | #2 |
Out of the carpool lane.
Re: 3.73 or 4.11??
If you're absolutely sure that you won't ever use it on the highway, then I'd go 4.11's!! Otherwise, I'd go 3.73 for that occasional long distance trip.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red 1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!) 2000 Honda VFR in the faster yellow! 2008 Husqvarna TE-610 1967 C-10 SWB 'Six Appeal'-Gone but not forgotten... |
06-01-2008, 07:27 PM | #3 |
Re: 3.73 or 4.11??
have to agree, gears make all the difference. if theres no highway, GO HIGHER
4.56!!
- Jason If you can turn, Youre not going fast enough. Favorite caption: first car to 200 mph in the 1/4 mile, no parachute, drum brakes all the way around.. ..back when men were men. |
06-01-2008, 07:42 PM | #4 |
Re: 3.73 or 4.11??
Ah.....that's lower
06-01-2008, 08:27 PM | #5 |
Junior Member
Re: 3.73 or 4.11??
It depends on what kind of performance you want, also tire size can affect things.
I am running 3.73 gears with 31's, for my kind of driving it works out great. Most of my driving is in town and country roads. Danny |
06-01-2008, 08:38 PM | #6 |
Re: 3.73 or 4.11??
I think you would like 3.55 with that turbo350 no overdrive, but thats my opinion.
Gulf Rat |
06-01-2008, 10:23 PM | #7 |
Re: 3.73 or 4.11??
No highway 4.56 its fun.
Troy 1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884 Big Red Dog build http://67-72chevytrucks.com/vboard/s...d.php?t=572274 |
06-01-2008, 10:29 PM | #8 |
Re: 3.73 or 4.11??
I've got 4.11's, posi and a very warm 350 and up to about 40 I have very limited traction with 30 inch tires that are 285's.
67 Short Step, 355, 700R 4.11 posi rear, 4/6 drop Discs on all 4 corners. Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=219094 |
06-01-2008, 10:42 PM | #9 | |
The LuvShack Garage
Re: 3.73 or 4.11??
a 3.55 or 3.73 but with "GQ's" motor & a 700R I think I'll be happy with it If it will NEVER see the highway then go MPG is gonna suck anyways.
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Tow Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
06-01-2008, 10:50 PM | #10 |
Project 7dos
Re: 3.73 or 4.11??
Tires are 275/60's = 28" tall... If your getting no traction with 30" tires... than what would that do with 28"!!! hahaa
06-01-2008, 11:27 PM | #11 | |
Re: 3.73 or 4.11??
Gulf Rat |
06-01-2008, 11:41 PM | #12 |
fugedaboutit
Re: 3.73 or 4.11??
I like my 3.73's. It really picked the truck up from the 3.08s and I can still go down the freeway @65 at right around 3k rpms. Im running a 28" tire. I drive it to the track and cross the finish line at around 4200rpms (1/4 mile) It would pick up a couple tenths with a lower (higher numerically) gear but driving the freeway would suck (gas that is). So my vote with no freeway driving would be the 4.11's Those would be a fun gear
Currently truckless |
06-02-2008, 01:23 AM | #13 | |
The LuvShack Garage
Re: 3.73 or 4.11??
of it. That way I can drive it long distances and get ok MPG. (Right now in the 4wd w/ 3.08's and a 350 auto I only get 8, yes only 8 MPG)
06-02-2008, 04:43 AM | #14 |
Re: 3.73 or 4.11??
I'm get 19 mpg if I drive 70mph, with a 350 mild cam Quadjet, no headers, daul exh. 3.73 gear.
Not bad for old 71 Chevy.. Gulf Rat |
06-02-2008, 08:08 AM | #15 |
Re: 3.73 or 4.11??
3:73 is about perfect with your tire combination.What motor are you running,and what are your cam specs.Too much gear with not enough cam and you'll be running out of motor.I had a 4:56 gear years ago and it was fun for about two weeks.Went back to 3:73s and never regretted it.Just my .02
06-02-2008, 03:19 PM | #16 |
Re: 3.73 or 4.11??
You're looking at a new rear axle, if Im not mistaken 4.11's won't fit in a pumkin that 3.07's came stock in. Pumpkin is too small-
Rottenwood Garage 1970...71...72 C1500 aka Orange aka Sideshow Bob 540 BB Straub Roller Cam, AFR Magnums, XP 950, TKO 600 2 Tons of Fun |
06-02-2008, 03:22 PM | #17 |
Re: 3.73 or 4.11??
ARE YOU SERIOUS??? What's your secret? I get about 13mpg w/ a built 350 and 3.07's!!! Ahh...but Im running a TH350. Do you have a 4 or 5 speed tranny?
06-02-2008, 06:31 PM | #18 |
Re: 3.73 or 4.11??
WOW 19 out of a carbed 350 HOW????
06-02-2008, 07:24 PM | #19 | |
Re: 3.73 or 4.11??
Gear manifacturers compensate for this as the ratio gets lower. They make the ring gear thicker to match the smaller pinion, but only so far. Then you have to have a "low ratio" carrier, which has the ring flange closer to center. |
06-03-2008, 02:21 PM | #20 |
Re: 3.73 or 4.11??
I call Especially at 70mph.
06-03-2008, 04:46 PM | #21 | |
Re: 3.73 or 4.11??
Gulf Rat |
06-07-2008, 01:10 AM | #22 |
Re: 3.73 or 4.11??
i have 373 with 295/50/15 with a saginaw 4 spd and a pretty warm motor but with what i have in the rear (gears and tires) what would it make my gears?
06-07-2008, 02:16 AM | #23 |
Gone to greener pastures
Re: 3.73 or 4.11??
Just curious, have you had your speedo calibrated?
'69 Chevy 1/2 T LWB Stepper: Daily Beater '72 GMC 3/4 T Fleet: Another Daily Beater '72 Plymouth Gran Coupe: ? "Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche "Never kick a fresh turd on a hot day." Harry S. Truman GUN CONTROL: Never having to say, "I missed you." Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck |
06-07-2008, 02:31 AM | #24 | |
Re: 3.73 or 4.11??
This is just what I have in LowBuck and love it. The lower 1st gear in the 700R4 gives you that 3.73 take off feel and the 27% OD gives that 3.08 cruise. At 70MPH I run right about 2000 RPM and that is perfect for the vett LT1. It is one of the most versatile truck combo's I have ever had and I have had alot Kevin LFD Inc. |
06-07-2008, 10:01 AM | #25 |
Re: 3.73 or 4.11??
