Old 06-01-2008, 09:53 PM   #1
salazar44
65 - Chevy C10
salazar44's Avatar
Rear Spring Removal
Anyone have any pointers on this before I replace them with some jeep springs. Pointers in regards to how-to... not necessarily why I shouldnt do it.
VIC
One Repair Leads to Another!
http://vix65chevyc10.blogspot.com
salazar44 is offline   Reply With Quote
Old 06-01-2008, 10:13 PM   #2
joe231
joe231's Avatar
Re: Rear Spring Removal
don't expect a quick and easy job. soak the bolts and nuts/cups with pb blaster.
3 out of 4 of my bolts broke, prepare for the worse and you won't be suprized
(if your rear suspension has been apart recently disregard this)
CHEVY ONLY
Old 06-02-2008, 12:37 AM   #3
salazar44
65 - Chevy C10
salazar44's Avatar
hmm... what bolt sizes do I need to replace it? I might as well get them now so I can have them ready.
VIC
Old 06-02-2008, 05:49 AM   #4
protrash64
Resistance is Futile
protrash64's Avatar
Hey man, its not extremely difficult but its definately not fun. I did mine last fall and it took awhile to get it done. I cannot for the life of me remember the bolt sizes......I think uses 11/16 or 3/4 socket........3/4" bolt? 5/8" bolt?
Just jack it up and let the springs extend so you can get in there. Having 2 or 3 jacks is helpful too!
I think the bottom bolt is about 5" long. It is the same size as the rest I believe.....dont quote me.........have fun.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 06-02-2008, 07:15 AM   #5
joe231
joe231's Avatar
Vic, they are 1/2"-13 bolts top and bottom. I used grade 8. bottom ones I got 1/2"-13 by 4 1/2" long. I think i got 1/2"-13 by 1" long for the top. I also had to flatten the lower cups, and when I did it knocked the welded square nuts loose, so I used flats, locks, and nuts instead. give me a shout if you have any more questions.
joe
hey Jeff, it is a 3/4" head and nut. I will remember that for awhile. when I got replacement bolts they didn't have 4 1/2", and 4" were too short, so i got 5"...turned out too long so used the 5" with extra washers just to get it on the road, then I got the 4 1/2" later and replaced them this last weekend, quick easy job, right. got the driver's swapped, was just finishing the passenger's side when the 1/2" ratchet and 3/4" socket slipped off and I hit myself in the head, blood everywhere, freaked out the family. not to mention anti-seize embedded in the sore.
here is a pic after it has healed for a week
perfect socket shaped dent
oh, and......never-mind the receding hairline
CHEVY ONLY
Old 06-02-2008, 07:43 AM   #6
ChopperDr
Hit the nuts with PB Blaster.http://www.pbblaster.com/index.html Do this every day for a few days. It's the ticket to working on old fasteners.
The Wrangler springs are a smaller diameter so they are a little loose in the mounts, but they seem to stay in. I like the spring rate, they ride pretty good.
Chopper
ChopperDr is offline   Reply With Quote
Old 06-02-2008, 10:16 AM   #7
1966-Suburban-V-8
1966-Suburban-V-8's Avatar
Originally Posted by joe231 View Post
....perfect socket shaped dent...
Youch! that's definitely gonna leave a mark! You shoulda been wearing a helmet when you were wrenching on that job. Next OSHA requirement on the way!
Dan
1966 Chevy Suburban 'Gater - Shop Truck - 350/turbo 350
Power Steering, B&M Floor Shift, Dual side dump exhaust
Chrome Rally 6 lugs. (((XM)))tunes!
1965 Riviera 425 - Luxury Muscle - Fully Factory Loaded. All power, A/C, Custom Interior, Guidematic Dimmer, AM/FM - etc, etc
1966 Corvair Corsa Turbo - Factory Sport Model - Quick steering, F-41 HD suspension, Positraction, Tele Wheel.
1966-Suburban-V-8 is offline   Reply With Quote
Old 06-02-2008, 10:29 AM   #8
joe231
joe231's Avatar
Dan
CHEVY ONLY
Old 06-02-2008, 10:30 AM   #9
salazar44
65 - Chevy C10
salazar44's Avatar
Thanks guys. Unfortunately I was not able to read the posts until this morning. I got the job done with a little muscle work. They were stuck pretty good but I used some penetrating stuff for rusty bolts. Luckily nothing busted and now my ride is sitting pretty! I am suprised as to how well it turned out.
Initially I only got an inch drop, but after removing the helper springs it went down to a 3 inch drop.
Not bad for $20!
VIC
Old 06-02-2008, 10:40 AM   #10
joe231
joe231's Avatar
how does the long bed ride with these springs?
CHEVY ONLY
Old 06-02-2008, 04:14 PM   #11
salazar44
65 - Chevy C10
salazar44's Avatar
feels pretty normal to me. I also had some helper springs already on. I plan on cutting them shorter incase i need to load some stuff on there, although i dont plan on it. But when they are on the bed goes from a 3" drop to a 1" drop... haha. I have some pics of everything, I will post them up later.
VIC
Old 06-03-2008, 01:50 AM   #12
salazar44
65 - Chevy C10
salazar44's Avatar
Ok.. so here are some before and after pics. I am pretty content with the rear drop, but still desire more in the front. It will get there.
Sorry but the only before pics with matching angles and while I had with same tires/wheels are when the truck was super WIP.
Front springs cut 1 coil, Rear springs swapped with 97 Jeep wranglers.
Before Angle1:
After Angle1:
Before Angle2:
After Angle2:
Spring Differences:
VIC
Old 06-03-2008, 01:50 AM   #13
salazar44
65 - Chevy C10
salazar44's Avatar
hmmm.. those pics dont really do the rear drop justice. Maybe this will help?
Before:
After:
VIC
Old 06-03-2008, 06:44 PM   #14
NF65Fleetside
NF65Fleetside's Avatar
daym look'n good mayn! your kill'n me on getting stuff done! come time to swap in my 6" rears then Im calling you! hehehe.
NF65Fleetside is offline   Reply With Quote
Old 06-03-2008, 07:08 PM   #15
joe231
joe231's Avatar
looks nice!
CHEVY ONLY
Old 06-03-2008, 11:45 PM   #16
TimE
Hey Y'all!!
TimE's Avatar
Dang! All I'm gettin are red X's. Oh well, I'm sure it looks cool!
TimE is offline   Reply With Quote
Old 06-04-2008, 12:01 AM   #17
greg64
greg64's Avatar
Looks great Vic! Glad you had the elbow grease to get her done.
Greg
64 GMC Suburban - 283, NV3500, 14 bolt
77 C10 swb - 292, SM465, 12 bolt
greg64 is offline   Reply With Quote
Old 06-04-2008, 01:12 AM   #18
salazar44
65 - Chevy C10
salazar44's Avatar
luckily for some reason things were not TOO bad. Dont get me wrong.. i wasnt smiling!
VIC
