PITbut
Any reason not to???
Any reason i SHOULD NOT have my cab sand blasted.???
Right now the engine is out, the cab is almost 100% stripped. Any reason i shouldnt get it done? Pros easy removal of old 4 layers of paint, unknown bondo glue around the doors easier cleaning and prepping for paint. Less time sanding off firewall. get a FRESH canvas on the underside of rig. Cons. Misc sand everywhere? removal of cab is hard?? Extra 250 bucks. I dont know.. Any other thoughts?? |
![]() Join Date: Apr 2008
Re: Any reason not to???
Using sand can warp the panels especially the roof.There are better media to use for sheetmetal
![]() Join Date: Feb 2004
Go for it just ask them to use a soda media, they should know exactly what to use and the correct pressures so as not to warp the cab.
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!" |
PITbut
fugedaboutit
![]() Join Date: Mar 2005
Im no expert on which media to use as far as what will warp, but I think for 250$ its worth it. I probably spent that on sand paper, dust masks, compressor maint. etc and still never took it all the way down thru the multiple layers. Youd be doing it right and the money would be about a wash.
As far as clean up.. Im still cleaning out dust from the old paint in all the little nooks of my truck using a DA so I wouldnt use sand everywhere as a con because your going to make a mess either way. Ive heard good about walnut shells for media but have no direct experience, maybe worth researching though. Just my .02.. Red
Currently truckless ![]() |
#6 | |
PITbut
They dont use soda.. Just plastics and sand... |
#7 | |
PITbut
fugedaboutit
Yup theres a fine line on how far you want to go! Pull the cab, mine as well pull the bed, suspension etc etc.. next thing you know its 2 years later and your truck is in 1000 pcs!! ( I know from exp)
Just a thought here but could you just trailer it to them, slide the bed back and have them do it on the chassis?
#9 | |
PITbut
Now, i will just have more room to do the tranny crossmember, and have the engine installed.. supa easy.... plus i can slide my bed forward to do the rear cnotch to.. seems to be win win at this moment.. |
fugedaboutit
There ya go! Would have been nice to have the cab off to do my xmember the upper bolts are a beotch with it on. Good luck with the project!!
#11 | |
id go for that
Travis
travis_moffatt@hotmail.com ![]() 1969 Chevrolet C-10 LWB, 350c.i., TH350, In Pieces. 1991 GMC Sonoma, IROCS s10 grill 1963 Ford Galaxie 351/C4 |
BlahBlahBlah
Who are you going to have do it?
#13 |
its all about the +6 inches
If the funds and time are there, i say go for it.
Acifd dipping can cause trouble, and probably costs more, so I would say steer clear of that. As far as clean up with media, it CAN be an issue, but a stripped cap would be minimal issue. It gets in window regulators, hinges, nooks and crannys, ect... but if the doors are off, that's most of the trouble spots. |
#14 |
Media blast but use an etching primer only. Otherwise your paint won't stick in places & you will be cussing later.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
#15 |
Using the Alternative Blasters guys in Arlington?
#16 | |
BlahBlahBlah
The thing about warping body panels can be true. But if you take it to a reputable shop that does this all the time you're going to be fine. Now if I tried to blast my panel body Im sure it wouldnt be pretty. ![]() |
#17 |
Marysville, Arlington...all the same ;-)
They did all the sheet metal on the front of my truck and did BEAUTIFUL work. I'm planning on having them do the frame on my parts truck as well. |
