Old 06-02-2008, 12:04 AM   #1
prg machine
prg machine's Avatar
headlight bucket assembly
can someone post a picture or diagram showing how the headlight buckets assemble to the core support for a 68 truck. I have mine all apart and off of the core for 4 years and can't remember how they go together
Thank you
69 K-20 cloned to a 67 with front clip and some other stuff.
383 .040 over
Crane roller cam lifters and rockers ,1.6 intake ratio, Open chamber heads, 9.5-1 compression ratio, 2.02 intake valves , Edelbrock performer Air Gap manifold Carter AFB performer 750cfm, MSD ignition, SM465 NP205 4.10 gears:
prg machine is offline   Reply With Quote
Old 06-02-2008, 10:11 PM   #2
prg machine
Re: headlight bucket assembly
anyone?
383 .040 over
Old 06-03-2008, 09:27 AM   #3
gcburdic
Restoration Virgin!
gcburdic's Avatar
Hey prg....
I got this from LMC....might help a little...
http://www.lmctruck.com/ICATALOG/CB/full.aspx?Page=154
By the way....do you have a Factory assembly manual??....It has a lot of good stuff in there to help with re-assembling the truck...especially after 4 years!!!.....
http://www.lmctruck.com/ICATALOG/CB/full.aspx?Page=158
look in the middle column at the bottom.....best $40 you'll spend!....Or maybe someone has one on here for cheaper!!!...
Good luck!
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 06-03-2008, 12:13 PM   #4
prg machine
Thanks for the info..............I guess the manual might be a good idea after all.
383 .040 over
