Old 06-02-2008, 06:51 AM   #1
Psycho 86
King Monkey Nut
Psycho 86's Avatar
Stuck emergency brake
My emergency pedal is stuck to the floor and wont release. How do I get it to release?? Any and all help would be greatly appreciated !!
Fear me for I am the keeper of nuts, the soldier of Monkeyness, I strike down those who try to oppose theKING MONKEY NUT!!
THROTTLE KING QUALIFIER This Yankee is gonna show them Rebels how the North muds !!
Psycho 86 is offline   Reply With Quote
Old 06-02-2008, 06:58 AM   #2
motopatzo
motopatzo's Avatar
Re: Stuck emergency brake
You'll have to go down where the pedal is and release it manually. Make sure you keep some pressure on the pedal with your hand when you release it. This is a very important step, because when I did it, I had my nose in the way and the pedal came up and busted my nose
motopatzo is offline   Reply With Quote
Old 06-02-2008, 09:26 AM   #3
89 crew
It is also possible that the e-brake cables are frozen up in the housing at the rear wheels. If that is the problem good luck! you will probably have to replace them.
89 crew is offline   Reply With Quote
Old 06-02-2008, 04:04 PM   #4
Psycho 86
King Monkey Nut
Psycho 86's Avatar
Thanks for the suggestions !! I found the problem....it was a huge chunk of clay/mud attached to the cable !! It dried out overnite and fell off !! Brake released with no problem this morning !!
