Old 05-07-2002, 09:36 PM   #1
big.l.a
big.l.a's Avatar
Post Rust Spot Questions
I just noticed my truck (71 C10) has pin
hole rust spot on the P-Side cab conner.
what's the best way to stop the rust. I do this I need to put a entire patch panel
over the small area do I? I also have a rust
hole about the 1/2 the size of a dollar(I guess It's from the acid in the battery).
on the P-Side front fender. This requires a
patch panel right?
71 C10 LWB With
Edelbrock 7101& 1406 Carb
Accel HEI Blue Print
Accel 8.8 Wires
Soon to have 3.40 possi &
186 Camel hump heads
Dropped 2-1/2F&4R
Dynomax Headers
Duals Flowtech Aftburners
Tonneau Cover Frm 89 F150
79 Monte C
71 C10 LWB With
Accel 8.8 Wires
Soon to have possi &
Dropped 2-1/2F&4R
Dynomax Headers
79 Monte C
big.l.a is offline   Reply With Quote
Old 05-07-2002, 10:04 PM   #2
Randy70C-10
Randy70C-10's Avatar
Post
Patch panels are the only true fix. Unless it's a show truck, I'd bondo over it and cover it with paint. As long as you kill the rust first, it will last a couple years. Tiger hair is great for patching small holes.
Yeah, that's right. My name is Randy too!
WWW.Randysrods.freeservers.com
1970 Chevy C-10 shortstep
30 Ford Model A Coupe 4 inch chop, 350, GMC 671 blower-Hell yeah it's fast!
87 Harley Sportster(couldnt get a 350 to fit)
Self Propelled Lawn Mower
Built in USA!!!!
Virginia Beach, VA.
Randy70C-10 is offline   Reply With Quote
Old 05-07-2002, 10:23 PM   #3
bigvinnie
bigvinnie's Avatar
Post
For the pinhole in the cab corner, try to push a screw driver in the hole and see if there's more rust, you might be surprised... if it's not too bad, you can mig weld the hole shut.
The fender rust will require a patch panel to be done right... if it's only half the size of a dollar, you could probably make one yourself...
'72 short step, 350, 700R4, tilt, ps, pdb, a/c, lowered coils, etc., other work in progress... San Diego, CA
http://www.ixpres.com/vlusardi/chevtrk.htm
72 Stepside Project
bigvinnie is offline   Reply With Quote
Old 05-08-2002, 07:54 AM   #4
Huck
Huck's Avatar
Wink
Might try pushing the rust area in a bit, soaking both the inner and outer area with POR15, then just cover it with bondo. Worked for me for 5 years so far. The only area this didn't work on was the little "pockets" on the bottom of the door corners where you can't get the POR 15 into the rust as it is actually inclosed within the two layers of metal. Good luck
72 Cheyenne, 350, 5spd, LWB, Super trim.
71 GMC JIMMY 4X4 --needs stuff-!
Huck is offline   Reply With Quote
Old 05-08-2002, 09:14 AM   #5
Woody
Post
Huck, Say the POR15 in the door corners didn't hold? I'm trying to do this to my doors now. They both have quarter/half dollor sized rust. I have POR15'ed from inside and out, and will use tiger hair fiberglass repair (this stuff is tough) then, silicone the inside seam (thru the corners)to keep moisture from entering from inside the door. Did you do anything to keep water from getting back in to the corners when you repaired your doors?
Woody
'69 Custom-10 Deluxe
Short Fleetside,Factory 350cid/TH400,A/C,PS,PB,Carpet
Coming soon 700R4, 350 Crate Engine, Pwr Disks...
Woody is offline   Reply With Quote
