06-02-2008, 11:16 AM | #1 |
Packrat
what are these pieces in the cab.
tried search, but Cab and spring doesn't narrow it down enough.
inside the cab, passenger side, behind the door frame, is a large spring looking thing. a large coil attached behind the latch area, with a small straight section, to a smaller coil. passenger side floor behind seat rail, a spring with a ring attached at the end. spring is attached to the cab floor.
gone: --'07 Tahoe LTZ 4WD --'68 Firebird 400 Convertible gone: --'72 Chevy K20 |
06-02-2008, 11:19 AM | #2 |
STOLEN
Re: what are these pieces in the cab.
They hold the Jack and Jack Hardware in place.
In Search Of |
06-02-2008, 11:43 AM | #3 |
mine holds a baseball bat... but it supposed to be to hold the jack and hardware like stated above...
1972 K10 4" lift, 35’s, 383 stroker, 700r4, current project. 1971 C10 3"/5" static drop, 355/350. "La Bamba.” The current daily driver. |
06-02-2008, 11:51 AM | #4 |
Arrived on a Pale Horse
Jason 87 V30 350TBI/400 White w/Boss V-plow 89 R3500 CC SRW |
06-02-2008, 12:18 PM | #5 |
Not trying to hijack your thread, but I found my jack/handle bolted to the left front inner fender. It looked factory to me, but I also have the spring/latch deal in the cab (68 C-10) that 72-c20 is asking about. Any idea which is correct?
06-02-2008, 12:41 PM | #6 |
this is a very informative thread about jack hardware placement
http://67-72chevytrucks.com/vboard/s...highlight=jack
PROJECT CIRCUIT RIDER |
06-02-2008, 01:02 PM | #7 |
Packrat
awesome. thanks. Mine will just be a storage area, as a stock jack won't do me much good. Need to mount in a hi-lift somewhere.... or stow under the seat....
06-02-2008, 01:10 PM | #8 |
Who's got steelies?
A hilift jack stores very nicely under the seat. I think mine is a 48". Just be sure to have it pushed in as far as it will go, or you will sone have problems with your passenger side door.
1969 C10 LWB W/ 250 I6 & 3spd 1970 C10 with '67 small window cab, 68 front end, blue; 305/TH350, 3.08 limited slip rear end, manual brakes, power steering; & 4-wheel drums-My daily driver. 1975 Chevelle Malibu Classic Coupe 350/th350 mint green 1970 C20 Suburban 350/700R4 4.10 gearing green & white 1978 Big 10 Silverado 350/th350, working ac, 2 tone blue-My summer daily driver 1983 GMC 1500 Sierra 305/SM465 2.73 rear end How to add a trip odometer to your 67-72 stock speedometer How to rebuild your Q-Jet My Truck Page My Youtube Channel |
