Old 06-02-2008, 11:55 AM   #1
my67chevytruck
Under Construction
my67chevytruck's Avatar
disk brake conversion question
Ok, maybe i am not searching correctly but i cannot find a thread in the FAQ that details everything i need, so i am asking the experts. Can someone point me to a detailed thread or let me know what i need off my 72 parts truck.
I have a 67 that i am building for my son, i bought a 72 roller with disk brakes and 5-lug rear to do the conversion. I have heard soo many scenarios i would like to know exactly what i need to pull off the 72 and install on the 67. I know i will need the booster/master , brake lines/clips, spindles rotors calipers. center link, upper lower ball joints ( will buy new for install) all steering linkage. 67 has ps now. do i need the upper or lower control arms... any suggestions would be appreciated, i am still new to the 67-72's, but loving it thus far.
Is it better to do a complete crossmember swap. I would have to rent a cherry picker.....
Thanks in advance.
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 06-02-2008, 03:35 PM   #2
70rs/ss
70rs/ss's Avatar
Re: disk brake conversions
I believe the upper and lower arms are the same, but ball joints etc are different, If buying new stuff use the 67 arms (or the 72's if they are better) and buy the new parts for a 72 w/discs. I think the mounting tabs for the brake lines are welded to the crossmember, so cut them off and tack weld them to the 67 crossmember. On a scale of what is best vs easiest, swapping the 72 cradle (crossmember and all the related stuff) would be better, maybe even easier in the long run but kinda labor intensive! Jack up the 72 and cut the bolts that hold the crossmember off then roll it out and repeat on the 67, use new grade 8 bolts to put it under the 67 then rebuild as needed.
70rs/ss is offline   Reply With Quote
Old 06-02-2008, 04:13 PM   #3
Ole Blue 68
Ole Blue 68's Avatar
Do the crossmember swap...
Ole Blue 68 is offline   Reply With Quote
Old 06-03-2008, 09:41 AM   #4
my67chevytruck
Under Construction
Ok, thanks for the suggestion , i should be ready to tackle this in a couple of weeks. Will the mounting holes all line up perfectly for the crossmember swap, or will new holes have to be drilled. I am trying to get all the info i can on this. Thanks in advance.
Heath
FAQ how to's
1956 Chevy Apache
56 chevy truck :
67 truck build:
69 k10:
Old 06-03-2008, 06:11 PM   #5
bigsnookmaster
bigsnookmaster's Avatar
All the holes will line up with no problem.You can probably make some kind of support to hold the engine in place while you do the swap.Taking the A-arm assys out and using your existing crossmember isn't that difficult either but it's just a little more awkward.
bigsnookmaster is offline   Reply With Quote
Old 06-03-2008, 08:29 PM   #6
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
Almost all the holes will line up. All but one on each side anyway. If you check out my 67 panel build up it gives instructions on what I had to do to change the whole crossmember. http://www.classicheartbeat.com/67_panel_project.htm WES
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 06-03-2008, 09:54 PM   #7
caminokid
Chevy nut
caminokid's Avatar
I put an 87 crossmember under mine. also used the p/s box too. All holes lined up.
84 Chevy Custom Deluxe 1/2 Ton Named Fade To Black II
"Remember kids there is NO replacement for displacement!"
caminokid is offline   Reply With Quote
Old 06-03-2008, 09:57 PM   #8
caminokid
Chevy nut
caminokid's Avatar
Heres the thread I started about mine.
http://67-72chevytrucks.com/vboard/s...d.php?t=292762
Old 06-04-2008, 11:01 AM   #9
my67chevytruck
Under Construction
Ok, thanks Wes, and camino kid. I will look over your threads... Thanks for the info.
Heath
FAQ how to's
1956 Chevy Apache
56 chevy truck :
67 truck build:
69 k10:
Old 06-04-2008, 01:11 PM   #10
NWD02
Maybe this will help....
http://67-72chevytrucks.com/vboard/s...58#post2737958
NWD02 is offline   Reply With Quote
Old 06-04-2008, 02:49 PM   #11
my67chevytruck
Under Construction
Thanks for the info. This will come in handy when rebuilding the front end.
Heath
FAQ how to's
1956 Chevy Apache
56 chevy truck :
67 truck build:
69 k10:
