Old 06-02-2008, 12:05 PM   #1
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
Carrier Size
OK, I want to get a Powertrax Lock Rite for my truck, But I'm not sure which carrier I have. The axle is a 12 bolt that used to have 3.08 gears in it. I had my friend put 3.73's in it from Richmond a long time ago, and he can't remmeber either. What carrier do I have? Did we change it over to the larger one or does it still have a small carrier in it?
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
Old 06-02-2008, 12:54 PM   #2
BowTieOgre
Re: Carrier Size
Sounds to me like you have a series 3 carrier (2.76-3.42). The aftermarket makes beefier series 4 type gears (3.73 and up) that fit on the 3 series carrier and that sounds like what your friend did.
1986 C10 - LWB, 305/700r4, posi, vortec heads
BowTieOgre is offline   Reply With Quote
Old 06-02-2008, 01:20 PM   #3
smashingchuck
Re: Carrier Size
We would have done the simplest and cheapest thing.
So I'd be safe with the 2.76-3.42 carrier size then? What's the measurement of that one 8.125?
78 Build Thread
4Runner Build
Old 06-03-2008, 10:48 AM   #4
smashingchuck
Re: Carrier Size
so whats the size of the carrier I have?
78 Build Thread
4Runner Build
Old 06-03-2008, 02:49 PM   #5
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
Re: Carrier Size
The simplest thing would have been to get a thick gearset that works with the 3.42 and down carrier. That would eliminate the need to get a new carrier.
If that is the case, you have the 2.76-3.42 (3 series) carrier and NOT the 3.73-up (4 series) carrier.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
