Old 06-02-2008, 01:01 PM   #1
avysittinon22s
avysittinon22s's Avatar
bagging front of 71 questions
Well I got the front suspension apart. Got the bumpstop bracket off the lower a-arm. Started to mount the cups in and decided to go ahead and cut the cup. I the cup is 2 1/4" tall so I think Im gonna cut an inch off. Should I cut anymore off? I also read where they replaced the arms with 73-87 arms. Should I do this? What are the advantages?
avysittinon22s is offline   Reply With Quote
Old 06-02-2008, 01:57 PM   #2
aggie91
I'm just glad to be here!
aggie91's Avatar
Re: bagging front of 71 questions
Originally Posted by avysittinon22s View Post
.... I also read where they replaced the arms with 73-87 arms. Should I do this? What are the advantages?
The only difference with the 73-87 arms from your 71 arms is the bushings on the cross shaft. The 71 uses a solid steel bushin where the 73-87 uses a rubber bushing. There are no upgrade kits for the 71 arms, but you can change the 73-87 to urethance bushing that are available from many companies. If your bushings in your 71 arms are good, I don't see any reason to change them.
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
