Old 06-02-2008, 07:07 PM   #1
stevelindsay
help with radiator bushing propper mounting
help please I cannot figure out how these go on.
stevelindsay is offline   Reply With Quote
Old 06-02-2008, 07:09 PM   #2
poncho_villa
poncho_villa's Avatar
Re: help with radiator bushing propper mounting
58 Apache short fleetside ona 64 chassis:
poncho_villa is offline   Reply With Quote
Old 06-02-2008, 08:34 PM   #3
JimKshortstep4x4
Here is a picture of the original bushings. The radiator support goes between the square plate and the top bushing. The frame is "trapped by the two bushings, (upper and lower). A 7/16-14x4 carriage bolt is used to hold it together.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 06-03-2008, 08:41 AM   #4
stevelindsay
thank you so much. The wholes in my mounts are a little to small so I will make them fix the new mounts. thanks again. steve
Old 07-06-2008, 08:53 PM   #5
Green Machine
Green Machine's Avatar
If the frame holes are to small, you are trying to put 69-72 mounts on a 67-68 frame. You will need to get the correct mounts for your frame. Even if you get them to fit the hole they wil be too thick. 69-72 had the steel mounts positioned lower on the frame to use a thicker mount and they went to a bigger hole also.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
