Old 06-02-2008, 09:06 PM   #1
1tonblaze
1tonblaze's Avatar
bracing up the body ??????
Well i am getting ready to take the hard top off my blazer for body work . the floor pans and rocker boxes are m.i.a thanks to being a plow truck in pa for along time . I dont want the body to fold up when i take it off . what has been some ways every one has done this ?
1970 k/5 blazer--> money pit - 14bolt dana 44 350 sm465/205 36 14.50 16 tires
1972 nova plane jane 6 clyinder might sell might keep dont know
2004 chevy s-10 crewcab zr5 sold
1985 c20 chevy long bed , beater , on its way to a better place in pa from what the dmv told me
2010 kia forte koup 2.4 sx -over the river and threw the woods to the total lot it went .
1999 k1500 suburban 350 vortec 4l60e leather land yacht .
1tonblaze is offline   Reply With Quote
Old 06-03-2008, 07:19 AM   #2
pound41
Re: braceing up the body ??????
Don't take the top off. Brace the door opening to help with the cowl when you cut out the kick panel etc. Get your floors, boxes etc done first then take the top off and do other body work
pound41 is offline   Reply With Quote
Old 06-03-2008, 08:11 AM   #3
Big J
Its lookin' like a Blazer!
Big J's Avatar
Thats the way I did it. Take a look through my build thread. I didn't take the top off until I was done with the boxes and floors. I didn't need to brace the doors though. Do one side at a time too. It'll help keep things in check.
BAZINGA!
My Build
Big J is offline   Reply With Quote
Old 06-03-2008, 06:02 PM   #4
DANTES JIMMY
DANTES JIMMY's Avatar
i didnt have to get that deep into mine but after looking through some of the other threads i agree
dont even loosen the top before making all the rocker box and floor repairs
maybe even make sure it hasnt allready "sagged" now
i didnt take the top off to cut out and repair my rocker panels and door jamb area just in case
it would be tuff or near improbable to realign with top off
i think
DANTES JIMMY is offline   Reply With Quote
Old 06-03-2008, 06:55 PM   #5
1tonblaze
1tonblaze's Avatar
thats the issuse i have another blazer that is being sold well the hard top needs to go with that truck that is being sold .
Old 06-03-2008, 10:58 PM   #6
Malibu 496
Junior Member
Malibu 496's Avatar
What if the body is already sagging with the top on?
What is the best way to get it straight without damaging anything else?
Thanks Josh
1970 blazer, street/strip project
1963 ford fairlane sports coupe 50,000 original miles
Malibu 496 is offline   Reply With Quote
Old 06-03-2008, 11:16 PM   #7
1tonblaze
1tonblaze's Avatar
mine was already saging and the doors where all hard to close i put the new body mounts in and it took care of all that . i had the top on when i did all this .
Old 06-04-2008, 05:00 AM   #8
jaros44sr
jaros44sr's Avatar
Can't ya just leave it on the frame and do all your repairs, use your doors as the gauge to check your work. Mark your hinges on the A post, and remount your doors to the A post every time(take out all the guts of the door)
Make your frame and body level and take lots of measurements as referance. As J said "do one side at a time"
Mine was as bad as yours, must be something with Pa. trucks
Just my .02 cents
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 06-04-2008, 07:20 AM   #9
Chevyman63
Can't wait to retire!!
Chevyman63's Avatar
I agree, my top is long gone and I have to do a firewall swap so my plan is to use the doors and build a brace or bracing with turnbuckles for adjustment. Hopefully it will work...we'll see.
2009 4x4 Chevy Crew Cab 6.0
1989 4x4 Siverado (270,000 miles)
1972 4x4 Blazer
2007 Chevy Cutaway 1 ton
1970 Corvette (sons project)
RIP
- CLR 10/11/09
Chevyman63 is offline   Reply With Quote
Old 06-04-2008, 07:54 PM   #10
1tonblaze
1tonblaze's Avatar
yeah that was what i was hopeing for just use the doors to hold everything together i have access to another hard top to use just the one that is on the truck needs to go with the one i am selling .
Old 06-13-2008, 05:58 PM   #11
1tonblaze
1tonblaze's Avatar
Re: bracing up the body ??????
anyone got anymore ideas ?????
Old 08-11-2008, 07:48 PM   #12
hellrazrblade
Purple People Eater
hellrazrblade's Avatar
ttt - I'm looking at pulling the top off of mine pretty much permanently - would it help to put in a new set of body mounts first? It looks like the body lift was just stacked on top of the old mounts.
1971 K5 Blazer 396ci/TH400/NP205/Dana 44/GM 12 Bolt/38" TSLs
2004 Chevy 1500 4X2 X-Cab 327ci
hellrazrblade is offline   Reply With Quote
Old 08-11-2008, 10:20 PM   #13
1tonblaze
1tonblaze's Avatar
I did all my body mounts with the top on and it held everything together pretty good . i still havent taken the hard top off of mine been to busy with the motor and drive train stuff to even worry about body work .
Old 08-12-2008, 07:30 AM   #14
vtblazer
vtblazer's Avatar
Having the top on is the preferred way but not the only way to achieve good results.
I used a gutted out truck door, that way I was sure the wing window strut would be correct and not bent out of shape like a blazer door can easily be.
START WITH GOOD HINGES!!
Mount the door and set the gap with to the windshield frame.
From there it's all about door opening measurements and the higher/lower orientation of the firewall to the bed floor.
An over simplified explanation but it should get you started.
If your gap at the windshield frame is good but your body lines with the quarter panel are low (door looks to be sagging) shim under the firewall...etc.
vtblazer is offline   Reply With Quote
Old 08-12-2008, 01:38 PM   #15
70rs/ss
70rs/ss's Avatar
http://67-72chevytrucks.com/vboard/s...=241695&page=3
This guy is an artist with metal, and his body bracing is spectacular. Do you need to do this, NO, but if you want to do it and have the best results, with the least amount of head scratching, this is the way I'd do it. For that matter, when my 2wd gets done I too will do it this way!!
70rs/ss is offline   Reply With Quote
