Old 06-02-2008, 09:36 PM   #1
chevyfan87
choke...and brake questions
how do i hook up the electric choke on an edelbrock performer 600cfm carb. originally i had a quadrapuke with the automatic choke from the thermal coil thing on the manifold....what do i need to do for this?
never had to do the swap before, just curious
also is there a better vacuum source for the brake booster than the carb? just wondering because i need to replace the line and everything and wanted to know what you thought
"tell ya what bub"
2000 gmc sierra 1500 4.3 4x4
too poor for the projects
chevyfan87 is offline   Reply With Quote
Old 06-03-2008, 06:35 PM   #2
us111
Re: choke...and brake questions
hello,just got a 1406,on the choke take your ground
wire from the - terminal on the choke and ground it
anywhere,they suggest lossening one of the choke screws
and mounting it to that.Take your hot wire + back to the
fuse block is the best place and attach it to a "switched)
terminal in the fuse block. the big port in the rear of the
carb is where it is suggested you hook power brakes to.
us111 is offline   Reply With Quote
Old 06-03-2008, 08:36 PM   #3
chevyfan87
yeah, well i heard someone say something about manifold vacuum, and i only know enough to break things so i figured id ask. i need to replace the booster line as it is because the fitting rusted to it and when i removed the previous carb i accidentally crimped it off. the ground is already hooked up on the choke, as the carb was used...(bought it off a friend for 25 bucks cause he was broke) so i just needed to know about the positive...thanks for the advice
"tell ya what bub"
Old 06-03-2008, 10:23 PM   #4
us111
yw,,hope it all works.
