new #186 flow numbers
Didn't think the dd2000 numbers for #186 heads sounded right..I did a search and found a shop that had these numbers...
"Here are some numbers from an unported set with 1.940" / 1.500" valves IN / EX .200 - 134 / 103 .300 - 182 / 122 .400 - 197 / 128 .500 - 203 / 132 .600 - 204 / 135 A simple bowl port with the 2.02" valve would up the numbers by 10%. Hope this helps. Mike Stark-CFM" these sound a little more real world Jim
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications click the clicky to join the site.... http://67-72chevytrucks.com/vboard/payments.php 67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44 Anderson,CA |
Thanx Jim. I'd loke to add that the bigger valves in factory heads need to be unshrouded at least 1/16", esp. the intake, or they produce no flow gains.
69 C10 longbed: 357c.i. /TH400/3.73s/AC/ beige primer/saving $ for paint ______________________________ |
That's great Jim. I have some serious doubt about the flow numbers and results from my DD2000. It's nice to see some real world proof, I was beginning to wonder??????
Member of the "Old Farts Club" |
