06-03-2008, 09:56 AM | #1 |
1962 C-10
Spare tire carrier problem.
I have an 04 Silverado z71. This morning it had a flat and I went to change it but the spare tire wouldn't drop... Has anyone had this problem before??
Joseph Chavez "See the USA in a Chevrolet!!" ......................_____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ 1962 C10 Shortbed Fleetside 327/th350 GV overdrive 1974 C10 Longbed Fleetside 350/th350 "The Trash Truck" 1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4 2015 GMC Sierra SLE 1500 4x4 |
06-03-2008, 10:46 AM | #2 |
Re: Spare tire carrier problem.
u might have to pull on the tire and while lowing it try t jerk it sounds like the cable is froze once you get ti down lube everything with a good white limitum Greece
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
06-03-2008, 10:50 AM | #3 |
1962 C-10
Figured it out... Thanks!
06-03-2008, 10:50 AM | #4 |
make sure it doesnt need the lock key on the end of the crank rod.it should be in the glove box (if it needs it ) looks like a locking lug nut key but smaller.just a thought
06-03-2008, 08:43 PM | #5 |
Drillin oil on American Soil!
i had the same prob, would only move an inch up or down, so i ended up taking the torch out and cutting it down. pos
Travis 70 Chevy c20 2wd 75 Chevy k10 4x4 parts truck 92 GMC Sierra c1500 2wd DD 99 Chevy Reg Cab Sht Box 1500 2wd 05 GMC Sierra Denali white |
06-04-2008, 09:43 PM | #6 |
pried on mine with 2 pieces of pipe, nothin. just left it for a later date. going to get a matching spare and mount it on the roof.
06-07-2008, 11:48 AM | #7 |
On the fast track to nowhere..
Just an FYI some of these had a problem with the spare being sucked up too tight and bowing the plastic tube you have to stick the rod through to drop the spare. There is an updated extension that is flexable to get it down if all else fails.
-Mike Owen- Norwood, Houston, Cecilia, Jackson, Monroe and counting |
